Friction during pure rolling up an inclined plane.
The discussion revolves around the forces acting on a cylinder that is pure rolling up and down an inclined plane. Participants explore the direction of friction during this motion and the implications of static friction in the context of pure rolling.
  • Participants examine the direction of friction while the cylinder moves up and down the incline, questioning whether static friction has a direction and how it relates to the motion of the cylinder.
Some participants have provided insights into the nature of static friction and its role in pure rolling, while others have raised questions about the implications of a frictionless incline and the conditions for pure rolling. Multiple interpretations of the frictional force's direction are being explored.
There is a discussion about the assumptions regarding the nature of friction in pure rolling and the effects of incline conditions on the motion of the cylinder. Some participants note the relevance of gravitational forces acting along the incline.
AlchemistK
A cylinder is pure rolling up an inclined place. It stops momentarily and the rolls back. In what directions is the force of friction directed during the journey?
While going up, the cylinder rotates in the anticlockwise direction, and so the friction acts up the plane. On the other hand, while rolling down, the cylinder rotates clockwise, and so the friction acts downward.
Which of those statements is wrong and why?
(As I started thinking, another query arose in my mind; since it is pure rolling, shouldn't the only friction be static friction? And so should that even have a direction?)
Yes it is static friction. It also has a definite direction.
If the incline were frictionless, would the cylinder's rotational rate change upon going up and down the incline?
Does static friction has a direction opposite to relative velocity, just like kinetic friction?
Would the cylinder rotate in the first place? There would be no torque to get it started.
And the book says that the answer is that the direction of friction is always up the plane, why is that?
The actual reason for friction to act in pure rolling is :
g sine ( theta ) acting along the incline causes an acceleration on the point of contact of the body. But the body is supposed to be in pure rolling I.e at the point of contact it should have zero velocity and zero acceleration. Since the nature of frictional force is to oppose relative motion making relative velocity zero..it opposes the mg sine ( theta) force and when this friction becomes equal to that value the body will be in pure rolling.
Coming back to the original question...
Whether the body is moving upwards or downwards...mg sine ( theta ) always acts down the incline so frictional force, to oppose the relative velocity , will always act in the direction opposite to it i.e up the incline..
And if the incline is frictionless there is no case of pure rolling unless an external force is applied opposing mg sine ( theta) force
Hope u got d concept...
alex.hs said:
The actual reason for friction to act in pure rolling is : ...
Hello alex.hs . Welcome to PF !
Do you realize that you've responded to a thread that's over 10 months old ?
I guess I did not observe..:shy:
We are actually learning that topic right now...so when I saw it, I just wanted to answer it.
Anyways...thank you SammyS for letting me know..:smile:
  • · Replies 30 ·
  • · Replies 42 ·
  • · Replies 35 ·
