Connecting two heaters of 240V to a relay rated at 240V
  • Thread starter Thread starter Etude
    Relay
The discussion revolves around the implications of connecting two 240V heater elements in series to a relay rated at 240V and 3A. Participants explore the potential effects on the relay and the output of the heaters, considering both theoretical and practical aspects.
  • One participant questions the impact on the relay and heater output when connecting two 240V heaters in series.
  • Another participant explains that connecting the heaters in series would result in reduced power output, suggesting that they would only receive half the power of a single coil.
  • A different viewpoint states that to achieve full power from both heaters, they would need to be connected in parallel, as series connection would require a higher voltage (480V) to function effectively.
  • Concerns are raised about the relay's capacity, noting that if the combined current draw of the heaters exceeds 3A (720W), the relay may be at risk of failure.
Participants generally agree that connecting the heaters in series will not provide full power and that the relay's current rating is a critical factor. However, there are differing opinions on the implications of the series connection and the necessary voltage for optimal operation.
Participants mention assumptions about the resistance of heating coils and the need to check the power ratings of the heaters to ensure they do not exceed the relay's specifications. The discussion does not resolve the potential long-term effects on the relay or the exact behavior of the heating elements under these conditions.
This discussion may be useful for individuals interested in electrical engineering, heating systems, or relay applications, particularly those considering the configuration of heating elements in relation to relay specifications.
Etude
Ok this might be a really stupid question but I would appreciate some help.
I have a controller with a relay output rated at 240 V 3A. I was wondering what happens if I connect 2 heater elements of 240 V each in series to this relay. Will it ruin the relay over time? Will the output of the heaters be affected?
Help is appreciated. :smile:
Welcome to PhysicsForums!
Making the naive assumption that your heating coils have constant resistance at all temperatures (they almost certainly won't, but also shouldn't change drastically for large values of drastic), what'll happen is that the in-series coils will only output a quarter of their power, and the sum of the two will result in only half the power output of a single coil.
You can see this by rearranging Ohm's Law, V=I*R, and the power formula, P=I*V:
[itex]P=\frac{V^2}{R}[/itex]
To double your power output, you should really connect the coils in parallel (so that 240V is present across each coil).
HOWEVER, you don't mention how much power your heating coils are rated for (or equivalently, how much current they consume). If they individually or together draw more than 3A (720W), you have a problem.
If this is the case, your relay may burn out because the coils are drawing too much current. Your controller might need to drive a relay driving the coils (either one supplying both in parallel, or two supplying one each)
If you connect in series two identical heating elements, each rated for 240 VAC, then when you power that series circuit with 240 VAC you will be disappointed at the low amount of heat produced. For full power, they'd need 480 VAC.
Though at 240 VAC, so long as the series combination doesn't draw more than 3A, the relay shouldn't be upset.
3 A at 240 V gives about 720 watts, check the heater ratings if they add up to more then 720 you need a bigger relay.
Thanx so much guys for your great explanations and quick response! :)
The three of your answers put together really explained the situation to me! Thanx a ton!
Am already feeling good about joining PhysicsForum!
  • · Replies 31 ·
  • · Replies 26 ·
  • · Replies 31 ·
  • · Replies 25 ·
