Question about the arrow of time?
  • Context: Graduate
  • Thread starter Thread starter phy_freak
    Arrow of time Time
The discussion centers around the concept of the arrow of time, particularly in relation to the behavior of systems as they transition between ordered and disordered states. Participants explore hypothetical scenarios involving time reversal and the implications for deterministic versus non-deterministic universes.
  • One participant questions whether a glass that breaks into pieces would necessarily scatter into the same number of pieces if time were to reverse and then move forward again, suggesting that the number of disordered states is greater than ordered states.
  • Another participant asserts that if the universe operates under deterministic laws, the glass would scatter into the same number of pieces, but if not, there is a chance it could scatter into a different number of pieces.
  • A participant references a book discussing the idea that if the universe were to contract back into a singularity and then expand again, Earth might not necessarily form in the same way, likening it to rolling dice.
  • One participant emphasizes that the question of whether the universe is deterministic remains unsettled.
  • Another participant introduces the 'many worlds' interpretation, suggesting that in such a framework, Earth would appear again, although this view is not universally accepted.
  • A later reply critiques the assumption that a universe running backwards in time would behave like a video played in reverse, arguing that this analogy oversimplifies complex physical laws, particularly regarding gravity and thermodynamics.
Participants express differing views on the nature of time, determinism, and the implications of time reversal. There is no consensus on whether the universe is deterministic or on the behavior of systems under time reversal.
Participants note the speculative nature of time travel and the need for clarity regarding the properties of space-time being discussed. The discussion highlights the complexity and unresolved aspects of the relationship between time, order, and physical laws.
phy_freak
I'm not sure if this is the correct section but I have a question I would like to be answered, I was thinking since a system will have many more possible disordered states than ordered states, then would this mean that if we were normally moving forward in time, and for example, some glass broke and scattered into 40 pieces, now if the whole universe went back in time, the scattered glass returned back into one piece of glass, and then time went forward again, would the glass necessarily scatter into 40 pieces again? or there is a chance that it will scatter into more or less pieces..?
Science news on Phys.org
It actually means that you can't go back in time.
With a lot of Universes, that glass would be unlikely to break the same way in two of them. But if you played space back and forth in time, since the glass already broke, it would play out the same way each pass through the events. It's like playing a recording - before the recording, anything could happen, but afterwards, it's set.
But to return to the point: since time travel is highly speculative you could also just say that anything could happen. To be useful you need to specify the properties of space-time you are trying to learn about.
Yes, provided that the universe is driven by a deterministic law.
There is, if the universe is not driven by a deterministic law.
But I've read in a book that if the universe contracted back into a singularity and banged again, Earth wouldn't necessarily form again, it's like throwing the dice again.. well, at least that's what I understood. And I thought that scientists still aren't sure if we are surrendering to a deterministic universe.. this issue is currently settled or..?
..earth wouldn't necessarily form again, it's like throwing the dice again..
demystifier's answer is the best short answer, I think...
and would likely be the relativistic type (classical) answer...but from a quantum theory perspective, if one subscribes to a 'many worlds' interpretation of things, meaning an infinite number of parallel worlds, then Earth surely would 'appear' again...in fact, it already has, but that's not, I think, the majority view...
and these conflicting views and theories are why it's 'unsettled'.
phy_freak
Don't be swayed by watching a video clip run backwards and then assuming that if time was running in the reverse direction, then that is how a universe running backwards in time would act - that all events would simply unwind.
Just sit back for a moment and contemplate a video clip of a a glass falling from a table onto the floor and breaking into 40 pieces next to a ball. Run the video clip backwards and sure enough the pieces somehow re-assemble into a glass which then jumps back up onto the table and stays there. And the ball rests on the floor undisturbed as no glass pieces hit it.
Doing a little thought experiment you contemplate: Is that is what would occur in a universe with time running backwards. And your scientific mind would ask " How is it that gravity is acting in the upward direction from the floor to the table, but not afterwards from the table. Why is it that the ball on the floor with glass pieces scattered all around had been, still remains on the floor and is not affected by the upwards gravitational force. Something mysterious is going on - reverse gravity acts only on certain objects"
You next contemplate other scenarios. If the universe running in a time reversal is the same as a movie clip running backwards then heat would have to flow from a cold body to a hot body - how does the heat know which hot body to go to. A light bulb would be absorbing light making the filament hot. A car putting on its brakes would make the car go faster and pressing the accelerator would make the car slow down. That sure would be a strange universe.
You can only conclude that a universe running backwards in time does not act like a movie running backwards, and 40 pieces of broken glass do not reform into the original whole glass.
  • · Replies 17 ·
  • · Replies 34 ·
9K
