Velocities seen from the center of mass
The discussion revolves around understanding the velocities of two masses connected by a spring as observed from the center of mass, particularly when one mass is given an initial velocity. The context includes theoretical considerations of the center of mass in a frictionless environment.
  • One participant describes a scenario with two equal masses connected by a spring and questions how to determine their velocities from the center of mass after one mass is given an initial velocity.
  • Another participant suggests calculating the center of mass velocity and proposes that the initial situation can be viewed as giving a thrust to the center of mass.
  • A participant questions the velocities of the masses and the center of mass as seen from one of the masses, proposing specific values for these velocities.
  • Further inquiry is made about how to approach the problem if the masses are unequal, indicating a need to recalculate the center of mass speed.
Participants express uncertainty regarding the velocities as seen from the center of mass and propose different methods for analysis. There is no consensus on the specific values or methods to apply when the masses are unequal.
Participants highlight the need for recalculating the center of mass speed when dealing with unequal masses, indicating that the principles of relativity may also be relevant to the discussion.
dapias09
Hello all,
I'm confused with the center of mass concept. Regard the following problem, we have a spring with negligible mass joined to two masses m1 and m2 (m1=m2) on a table without friction force. At t=0 a thrust Vo (initial velocity) is given to m2 with direction perpendicular to the spring direction (see figure adjoint). How are the velocities at t=0 seen from the center of mass?
At t=0 the m1 velocity seen from the laboratory is zero but this particle isn't fixed on the table.
Well, I guess that I should calculate the velocity of the center of mass as:
Vcm = m1V1 + m2V2 / (m1 + m2) = m2V2 / (m1 +m2) = Vo / 2, since m1 and m2 are equals.
So the initial situation is equivalent to give a thrust to the center of mass with velocity Vo/2, but how I know what are the velocities of m1 and m2 seen of the center of mass?
Can anyone help me?
Thanks in advance.
dapias09 said:
Hello all,
Can anyone help me?
Thanks in advance.
Ask yourself, instead, what are the velocities of m1 and the center of mass seen from m2. If you can figure that out for m2, use the same method for the center of mass.
Good idea!, James, thank you.
Just to check, isn't it -Vo for m1 and -Vo/2 for the center of mass seen from m2?
In this way, I have another question, do you know what should I do if the masses (m1 and m2) are different.
Greetings.
Greetings.
In regards to your first question, if they are not, what does that say about the principle of (Galilean) relativity?
In regards to your second, clearly, the center of mass speed needs to be recalculated. The rest is the same as before :)
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 21 ·
