Joint Distribution of Complicated Variables
The discussion revolves around the computation of joint distributions for complex functions of random variables, specifically focusing on the case of independent variables defined on the interval [0, infinity]. Participants explore methods for determining the joint distribution of expressions like (X/(Y+1)) and discuss the implications of using different types of functions.
  • One participant inquires about the approach to finding joint distributions for general cases, specifically for the expression (X/(Y+1)).
  • Another participant suggests a method for computing the cumulative distribution F(r) by examining the inequality g(x,y) <= r and integrating the joint density over the relevant areas.
  • There is a clarification regarding the expression, with a participant questioning if the intended expression was X/(Y+1) instead of X/Y+1.
  • A participant proposes visualizing the solution set for the inequality X/(Y+1) <= r and integrating the joint density over the area defined by this curve.
  • One participant raises a question about the applicability of the proposed strategy to non-continuous functions, such as step functions or min/max functions, and how to determine g(x,y) in such cases.
  • Another participant requests clarification on the concept of determining g(x,y) when the quantity is always changing, seeking an example for better understanding.
Participants express various viewpoints regarding the methods for calculating joint distributions, with no consensus reached on the applicability of the proposed strategies to non-continuous functions or the interpretation of changing quantities.
The discussion includes assumptions about the independence of variables and the nature of the functions involved, which may affect the validity of the proposed methods. There are also unresolved questions regarding the integration limits and the behavior of non-continuous functions.
raging
Simple joint distributions such as X+Y are usually worked out in textbooks, but how would we approach a general case. For example, let X any Y be independent variables each defined on the interval [0,infinity], and having densities f(x) and f(y) respectively. How do we find, for example, the joint distributions of (X/Y+1)? Anyone have any lead into?
The general idea for computing the cumulative distribution F(r) = probability that g(x,y) <= r for a function g(x,y) of two random variables would be to examine the implications of of the inequality g(x,y) < = r. For a particular r, you must determine what areas contain points (x,y) such that g(x,y) <= r. Then you must compute the probability that x and y both fall in these areas by integrating the joint density of (x,y) over those areas.
It is not always possible to do this calculation in symbols and get a concise formula for the answer. It may be necessary to use some algorithm to compute a numerical approximation to the answer.
There may be more specialized ways of doing the work when g(x,y) is a special kind of function - like g(x,y) = x + y, which you mentioned.
Do you mean X/(Y+1) ?
The general method would say to look at the solution set to
X/(Y+1) <= r
Perhaps you can visualize this set by pretending that Y is a constant and looking at the curve of the x's that satisfy X = rY + r. Then decide if all the x's on one side of this curve satsify the inequality. Then visualize the area swept out by the curve as you vary r.
Presumably you get some boundary curve or curves for the area and these curves are a function of r. You must integrate the joint density over the area. The curves would be incorporated into your limits of integration, so the integral woud be a function of r.
I'm not going to tackle those details myself unless there some interesting question about that particular g(x,y)!
I see. Thanks for the comment! I guess something like X/(Y+1) this just becomes a vector calculus problem. But would you strategy work for non-continuous functions as well? For example, the step function or the min and max functions? How would we decide what g(x,y) is less than if that quantity is always changing?
I don't understand what you mean by that. Can you give an example?
  • · Replies 30 ·
  • · Replies 43 ·
