Exponential Growth of Bacteria
The discussion focuses on the exponential growth of a bacteria culture starting with 840 bacteria, which grows to 2520 in 3 hours. The user initially calculated the time to reach 1030 bacteria as 0.557 hours but received an incorrect response from Webwork. The correct time, calculated with greater precision, is approximately 0.5568 hours. The discussion emphasizes the importance of using more digits during calculations to avoid roundoff errors and suggests that Webwork may require answers in a specific format.
  • Understanding of differential equations, specifically exponential growth models.
  • Familiarity with natural logarithms and their properties.
  • Basic knowledge of calculus, particularly integration techniques.
  • Experience with online homework systems like Webwork.
  • Learn about the implications of precision in numerical calculations.
  • Explore the use of differential equations in biological modeling.
  • Study the properties of logarithmic functions in depth.
  • Investigate best practices for submitting answers in online homework systems.
Students studying calculus, biology students interested in population dynamics, and anyone using online platforms for math homework.
τheory
A bacteria culture starts with 840 bacteria and grows at a rate proportional to its size. After 3 hours there will be 2520 bacteria.
How long will it take for the population to reach 1030 ?
2. The attempt at a solution
dP/dt = k*P
dP/P = k*dt
*Integrated both sides
ln |P| = k*t + C
P = e^(k*t + C)
*Used (0, 840) as initial values
840 = e^(k*0 + C)
C = ln840
P = e^(k*t + ln840)
P = 840e^(k*t)
*Used (3, 2520) to solve for k
P = 840e^(k*t)
2520 = 840e^(k*3)
k = 0.366
*Solved t when P = 1030
P = 840e^(0.366*t)
1020 = 840e^(0.366*t)
t = 0.557
I submit this as the answer on Webwork but it says the answer is wrong; can anyone explain to me why?
dP/dt = k*P
dP/P = k*dt
ln |P| = k*t + C
P = e^(k*t + C)
840 = e^(k*0 + C)
C = ln840
P = e^(k*t + ln840)
P = 840e^(k*t)
P = 840e^(k*t)
2520 = 840e^(k*3)
k = 0.366
P = 840e^(0.366*t)
t = 0.557
A more precise answer is t = 0.5568266199 hr. Perhaps the Webwork system wants more accuracy than you provided; in this Forum we have seen many instances where on-line answers have been rejected because of insufficient numbers of digits. You could try re-submitting a more accurate value, such as 0.5568 or 0.55683. Or, maybe Webwork does not want the '0' before the decimal, so might prefer you to write .557 or .5568. (Actually, that sounds like a badly-written system, but what can you do?)
BTW: in computations of this type, ALWAYS use more digits _during_ the computation, possibly rounding off the final answer; that helps to reduce the chance of incorrect results due to roundoff accumulation. For example, you should use a more accurate value of k; the precise value is k = (1/3)*ln(3) =~= 0.3662040963 =~= 0.36620.
RGV
Thanks, I tried resubmitting with the following:
[itex]\frac{3ln(103/84)}{ln3}[/itex]
Which equates to about 0.556 and gave me the right answer.
  • · Replies 25 ·
