| New Reply |
Linear Algebra: Matrix Transformations |
Share Thread | Thread Tools |
| Feb4-12, 08:58 PM | #1 |
Some matrix transformations [itex] f [/itex] have the property that [itex] f(u) = f(v), when u ≠v [/itex]. That is, the images of different vectors can be the same. For each of the following matrix transformations [itex] f : R^{2} → R^{2} [/itex] defined by [itex]f(u) = Au [/itex], find two different vectors [itex] u [/itex] and [itex] v[/itex] such that [itex] f(u)=f(v)=w[/itex] for the given vector [itex] w[/itex]. A = [tex] \begin{pmatrix} 1 & 2 & 0\\ 0 & 1 & -1\\ \end{pmatrix} [/tex] w= [tex] \begin{pmatrix} 0\\ -1\\ \end{pmatrix} [/tex] 2. Relevant equations My professor noted that there was a typo in the book, and that instead of [itex] f : R^{2} → R^{2} [/itex], it should be [itex] f : R^{3} → R^{2} [/itex]. 3. The attempt at a solution My professor has been on jury duty for the past week, and our sub just assigns us homework without much instruction or guidance. We haven't been properly introduced to the notation [itex] R[/itex], either. But from inferring from the problem, is it safe to assume that [itex] w = Au [/itex]? Also, would I have to use something along the lines of u = [tex] \begin{pmatrix} x\\ y\\ z\\ \end{pmatrix} [/tex] ? Detailed instruction would be much appreciated, as I am anxious to grasp the subject matter. |
| Feb4-12, 09:35 PM | #2 |
Recognitions:
yes w = Au means that the (column) vector w is equal to the matrix product of the matrix A and the (column) vector u.
so if u = (x,y,z)T, then Au = (x+2y,y-z)T so you need to find 2 different triples: u1 = (x1,y1,z1)T, u2 = (x2,y2,z2)T, such that: Au1 = Au2 = w = (0,-1)T. one way to do this, is to solve the linear system of equations: x + 2y = 0 y - z = -1 if you do this correctly, you should wind up with a "free variable". two different choices for this free variable will give you two different u1, u2. (as for the "R" notation, R2 means simply the set of pairs of real numbers, and R3 is the set of trios (triples) of real numbers. these are given a notion of vector addition by "adding coordinate-by-coordinate" and a notion of scalar multiplication by "scaling each coordinate by a real number" that is, multiplying each coordinate by the same real number). |
| New Reply |
| Tags |
| linear algebra, matrix, transformation, vectors |
| Thread Tools | |
Similar Threads for: Linear Algebra: Matrix Transformations
| Linear algebra proof (matrices and linear transformations) | Calculus & Beyond Homework | 2 | ||
| Matrix of Linear Transformations | Calculus & Beyond Homework | 3 | ||
| Another linear algebra problem, basis and linear transformations. | Calculus & Beyond Homework | 7 | ||
| Linear Algebra - Linear Transformations, Change of Basis | Calculus & Beyond Homework | 3 | ||
| Linear Algebra (Vector spaces, linear independent subsets, transformations) | Calculus & Beyond Homework | 12 | ||
