∫dx/((x^(2/3)(x+1)), integrated over [0,∞]
  • Thread starter Thread starter Jamin2112
The discussion revolves around evaluating the integral of the function 1/((x^(2/3)(x+1))) over the interval [0,∞], utilizing complex analysis techniques such as the Residue Theorem.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of the fractional power in the integrand and its effects on the contour integration. There are discussions about the necessary contour to avoid branch cuts and poles, with suggestions on how to construct the contour to correspond to the original integral.
The conversation is ongoing, with participants providing guidance on contour selection and the structure of the integral. Multiple interpretations of the contour path are being explored, and there is a focus on understanding the implications of the chosen paths on the evaluation of the integral.
Participants are considering the complexities introduced by branch points and cuts, as well as the need to avoid certain singularities in the complex plane while ensuring the contour aligns with the original integral's requirements.
Jamin2112
As in thread title.
Residue Theorem.
I just need help figuring out the circle C I'll be using. Suggestions?
What does the presence of z2/3 tell you?
Other than that there's a pole at z=0?
Yes, other than that. In particular, what's the effect of the fractional power?
Change the distance between z and the origin from r to r2/3
Change the angle between z and the x-axis from ø to 2ø/3
Right. Do you know what a branch point and a branch cut are?
Yeah, I somehow need a loop that avoid z=-1 and z=0. Right?
It's more that you want to avoid crossing the branch cut than avoiding z=0, and you obviously want a piece or pieces of the contour to correspond to the original integral.
So I'd take R>1 and make a half circle of radius R in the upper half of the plane. Then I'd make two little half circles that jump over z=-1 and z=0. Then I'd look at ∫C f(z)dz as the sum of several integrals, one of which can written as a real-valued integral and see what happens as R→∞ and the radii of the little half circles go to zero. Right?
Doesn't the answer to that question depend on which way Pacman is moving?
I forgot that PacMan is in perpetual motion.
But yeah, how am I going to do this? I need C to be formed from a series of paths, each of which will have a line integral that approaches a real value after I take some limit.
Start by taking the keyhole contour and break it into four pieces and evaluate the line integral for each piece.
How would that work? I want ∫f(x)dx (integrated on [0, R]) to be one of the four line integrals.
That's what you're supposed to figure out. :smile: Did you understand the example on Wikipedia? That's pretty much the recipe you want to follow.
  • · Replies 54 ·
19K
  • · Replies 105 ·
13K
