Wind Power Generation Comparison
This discussion focuses on comparing two potential sites for wind power generation based on wind speed and operational hours. Site one has a wind speed of 7 m/s for 3000 hours annually, while site two has a wind speed of 10 m/s for 2000 hours. The energy per unit mass is calculated using the equation e=KE=(V^2)/2, resulting in 24.5 J/kg for site one and 50 J/kg for site two. The conclusion drawn is that site two is more efficient due to its higher energy output, despite operating fewer hours.
  • Understanding of kinetic energy equations in physics
  • Knowledge of mass flow rate concepts
  • Familiarity with wind power generation principles
  • Basic proficiency in energy calculations
  • Research the calculation of mass flow rate in wind energy contexts
  • Explore the impact of wind speed on energy generation efficiency
  • Learn about different wind turbine designs and their efficiency ratings
  • Investigate annual energy output calculations for wind power sites
Engineers, renewable energy analysts, and students studying wind power generation who seek to understand site selection criteria and energy efficiency calculations.
OUmecheng
Two sites are being considered for wind power generation. In the first site, the wind blows steadily at 7 m/s for 3000 hours per year, whereas the second site the wind blows at 10m/s for 2000 hours per year. Assuming wind velocity is negligible at other times for simplicity, determine which is a better site for wind power generation. Hint: note that the mass flow rate of air is proportional to wind velocity.
e=KE=(V^2)/2
E = me
Ok so I found e1 and e2 with the first equation.
Which gives me 24.5 and 50 J/Kg (respectively)
But I'm stuck now. How can I find m? It says that that the mass flow rate of air is proportional to wind velocity but how can I tie in time? Any hints would help.
I can tell that the second site would be more efficient, but I can't explain why.
They are probably wanting the site with the highest annual mass flow, where
mass flow = mass flow rate x time
  • · Replies 33 ·
