Calculating Power for a Tractor Pulling a Loaded Sled at Constant Speed
  • Thread starter Thread starter DethRose
    Power Work
The discussion focuses on calculating the power required for a tractor pulling a loaded sled with a mass of 4110 kg at a constant speed of 45 km/h, facing a friction force of 585 N. The net force calculated was 39734.1 N, but the key to finding power lies in the relationship between force, distance, and time. Power is determined using the formula P = F x v, where F is the friction force and v is the speed converted to meters per second. Consistent unit usage is critical for accurate calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of work and power
  • Ability to convert units (e.g., km/h to m/s)
  • Basic knowledge of friction forces in physics
  • Learn how to convert speed from kilometers per hour to meters per second
  • Study the relationship between work, force, and distance in physics
  • Explore the concept of power in mechanical systems
  • Investigate real-world applications of power calculations in machinery
Students studying physics, engineers working with mechanical systems, and anyone interested in understanding the dynamics of forces and power in practical applications.
DethRose
Hey this is my last work and power problem haha...this is the hardest of them all.
the question is
A tractor pulls a loaded sled, massing 4110 kg, along a level snow packed road at a constant speed of 45 km/h. If the amount of friction between the road and the sled is 585 N find the power required.
I found the weight of the load in Newtons to be 40319.1 Nand subtracted the friction to get a net force of 39734.1 N but i don't know how to find the power from here.
help please
I am not sure why you are doing that. The mass of the sled is irrelevant since you know the actual force of friction.
Power is: Work (against the friction force) / unit time. Work is: Force (friction) x distance. So power is Force (friction) x distance/unit time = Force (friction) x speed.
AM
Make sure you use consistent units as well. If you're going to use Newtons, then you need to use m/s as well instead of km/hr. More generally, for reasons pointed out by Andrew Mason, power is given by:
[tex]P=\vec F \cdot \vec v = |\vec F| |\vec v| \cos{(\theta)}[/tex]
12K
12K
9K
