Can a photon have energy of spin?
  • Context: Graduate
  • Thread starter Thread starter James_Harford
    Energy Photon Spin
The discussion revolves around whether a fundamental particle, specifically a photon, can possess energy attributable to its spin. Participants explore the implications of angular momentum transfer from photons to materials, referencing a specific article on the topic. The conversation includes theoretical considerations and interpretations of experimental findings.
  • One participant questions whether the energy of a point-like particle can include a component from its spin, suggesting that traditional views may not fully capture the complexities involved.
  • Another participant argues that any "energy associated with spin" is unrelated to the cited article, emphasizing that angular momentum can exist without contributing to energy in the way the original poster suggests.
  • Concerns are raised about the interpretation of the article's abstract, particularly regarding the transfer of angular momentum and energy from photons to the material, with one participant expressing confusion over the implications of zero initial angular momentum in the light beam.
  • Further clarification is sought on how the material acquires rotational energy if the incident light beam is stated to have no initial angular momentum.
Participants express differing views on the relationship between spin, angular momentum, and energy transfer. There is no consensus on whether photons can have energy associated with spin, and the discussion remains unresolved regarding the implications of the referenced article.
Participants highlight potential ambiguities in the article's abstract, particularly concerning the definitions of angular momentum and energy transfer. The discussion reflects a reliance on interpretations of the article without direct access to its content.
James_Harford
I have been asking myself of late whether or not the energy of a fundamental (point-like) particle has a component attributable to its spin. My understanding has been that a point-like particle has no energy of spin because its moment of inertia is zero.
This article appears to both agree and to imply the opposite (see words in bold below):
Competition between spin and orbital photon angular momentum transfer in liquid crystals
Abstract:
We present a theoretical and experimental study on the transfer of angular momentum from a light beam to a nematic liquid crystal film. In the angular momentum transfer process photons are not destroyed, but scattered in a different angular momentum state: a process known as self-induced stimulated light scattering (Santamato E, Daino B, Romagnoli M, Settembre M and Shen Y R 1988 Phys. Rev. Lett. 61 113-16). Each photon in the incident beam transfers to the material only the change of its angular momentum, producing a torque on the body. Under the action of this torque, the body starts to rotate, changing, in turn, the amount of angular momentum extracted from the light beam. The process is intrinsically nonlinear and, as proved by the experiments reported in this paper, it can be initiated by a light beam carrying no angular momentum at all.
-- Piccirillo et al 2002, Journal of Optics B: Quantum and Semiclassical Optics, Vol. 4 No. 2
And yet this implies we can compute an amount of rotational energy contributed by each photon, i.e. the rotational kinectic energy of the body divided by the number of photons "scattered" by the body.
A way out of this paradox may be in the words "spin" and "orbital", which appear in the title but not the abstract. I have not read the article itself, as I am uncertain the access fee will purchase enlightenment or just regret about the $24.
Thanks in advance!
Any "energy associated with spin" has nothing to do with the article you cited. The point there is that angular momentum is a vector quantity, so whilst you can't have negative energies, you can have a system with zero total angular momentum whose components start spinning so long as their separate angular momenta add up to zero.
As for your original question, I think you're right that it makes no contribution to the energy. The idea of a particle as an infinitesmal ball spinning about some axis is misleading anyway; spin is a fundamental property of elementary particles, like charge. (Quantum mechanically it's associated with a degeneracy of states that transform into each other under rotations; spin only affects the energy when something like a magnetic field spoils this degeneracy by picking out a preferred direction). Any energy associated with spin would be present in the particle at rest, so there'd be no way of separating it out from the rest energy E=mc^2 of the particle anyway.
Hope that helps.
Thank you for your thoughtful reply. Your final observation was particularly convincing.
Nevertheless, it seems to me that the abstract cannot be right in saying "Each photon in the incident beam transfers to the material only the change of its angular momentum". The material is acquiring rotational kinetic energy from the light beam as well as angular momentum which is equal and opposite to the angular momentum (spin or orbital?) of the "scattered" photons. I use quotes here because the abstract applies "scattered" to angular momentum states and not to the relatively familiar concept (for me) of linear momentum states. But no change of linear momentum implies no transfer of energy to the material. So where does the material get its rotational energy? Perhaps they explain it all in their paper.
And thank you. Your comments give me a feel for the correct form of the answer to my question, except for the aforementioned details raised in the paper. Therefore, the particle addressing you remains grateful, but in a slightly disturbed state of confusion.
Ah now I understand your confusion. I took that abstract to mean not that no energy was transferred, but that the beam did not lose any initial angular momentum, hence the final remark.
It doesn't seem to add up. According to the abstract, the incident light beam can have no initial angular momentum.
So,
1. How can the material acquire a nonzero angular momentum if every photon transfers its angular momentum, when the incident light beam has zero angular momentum?
2. Where does the rotational energy of the crystal come from, if not rotational energy of the light?
- Regards.
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 44 ·
18K
