New Reply
Bohr-Einstein debate: why did Bohr not simply say...
Share Thread Thread Tools
Feb6-12, 09:51 PM   #1
Hello,
We've all heard of the Bohr-Einstein debates to some degree (the essence of them being: Einstein tried to convince Bohr that the uncertainty principle is not true by claiming to have found concrete thought experiments that seemed to violate it). Bohr countered Einstein's arguments.
But what I don't understand is why Bohr not simply said "but you're using classical reasoning", since Einstein heavily depended on classical conservation laws, for example that of momentum. Okay conservation of momentum is still true for statistical averages in the QM formalism, but Einstein really used them classicaly: imagining one particle bouncing off a wall imparting momentum to the wall in such a way as to keep the total momentum fixed.
For example, if Bohr hadn't given the conclusive counter-arguments which he did (incidentally also using classical conservation laws), would others have accepted Einstein's reasoning? Or would they simply have countered with "yes but you're using a classical reasoning"? I think the latter. Hence I'm confused why Bohr didn't immediately answer with it.
NOTE: please don't reply with "the UP is merely a statistical statement that can be derived from the formalism and which talks about the standard deviations of the position and momentum distribution": I know this, but this is not in the least what the above question is about.
EDIT: some people apparently, for some reason, interpreted my OP as inviting general comments about Einstein's realistic view, which is not what this thread is about, every sentence I wrote down was supposed to be specific to the two thought-experiments Einstein brought forth in the Bohr-Einstein debates and are not with a greater generality than that. My question is simply why Bohr thought Einstein's reasoning using classical concepts such as conservation of momentum (not averaged) was a serious threat, saying things like "it would be the end of physics if Einstein were right" etc, although these concepts are not really part of quantum mechanics and so can hardly be used to derive a contradiction.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Understanding job committment may lead to better correctional employees
>> The strangely familiar browsing habits of 14th-century readers
Feb6-12, 10:34 PM   #2
Quote by mr. vodka View Post
Hello,
Bhor probably did try to explain that to Einstein, but Einstein was so resistant to quantum mechanics (even publicly) that Bhor probably gave up trying to explain things in terms of QM and instead tried to find a way to explain how Einstein as wrong even in his own world.
To quote Einstein,
-"God does not place dice"-
And he still said that even when we knew that he/she/it actually did.
Einstein always thought there was hidden variables determining the random chaotic patterns of QM in order to fit his philosophy of a grand harmony of deterministic mechanism for the universe, but QM has discovered that is not possible, and he probably resented QM for suggesting that.
Feb6-12, 10:58 PM   #3
I believe in one thought experiment Bohr replied to, his answer relied on the macroscopic object obeying Quantum Theory.
Feb6-12, 11:02 PM   #4
Recognitions:
The disagreement between Bohr and Einstein is more subtle than that. Einstein famously said that the moon is there even if he's not looking at it; if Bohr had Einstein's capacity for one-liners he might have responded that as long as you're not looking at it, it doesn't matter whether it's there. That's the difference between realism and not, and that's way deeper than "classical" or not.
Is it interesting to consider how Einstein might have changed his thinking if he had lived to see Bell's theorem? I think so... but Bohr might have rejected the question as meaningless because it didn't happen.
Feb6-12, 11:08 PM   #5
I'm not satisfied with either replies, questionpost's post is way too speculative, and stevieTNZ seems to miss the point.
@questionpost: First of all, I'm familiar with the history of things, and I think you're misrepresenting. Einstein wasn't as ignorant as you're describing him. Also, your statement that "QM has discovered that is not possible" is simply not true (look up "de Broglie Bohm pilot wave theory"). But let's not make it about that, it's too off-topic and hot enough to get lost in. What pertains to your on-topic answer: your guess that Bohr simply followed into "Einstein's world" to pleasure Einstein seems too speculative; Bohr gives no indication whatsoever of this view. I'm not saying you're wrong, but it's not very convincing as it stands.
@StevieTNZ: Indeed he did, but that's not really the point. He and Einstein both used a (partially!) classical reasoning in the sense of using the classical concepts of particles bouncing around, obeying conservation of momentum. Indeed Bohr superimposed the uncertainty principle on it, a highly unclassical concept, but my problem is more with "why did Bohr toleratore the classical concepts Einstein used" even though they're not present in the actual quantum theory. One might even wonder why Einstein tried to use the classical reasoning (when trying to debunk QM) in the first place, since I'm sure he was aware QM doesn't use those concepts. It all makes me feel like I'm overlooking a big point.
Feb6-12, 11:11 PM   #6
Quote by Nugatory View Post
I'm aware of this; grosso modo Einstein was a realist and Bohr was a positivist, but I'm not sure how this answers my question? If it was intended to, can you clarify?
Feb6-12, 11:52 PM   #7
Recognitions:
As I read the original question, you were asking why Bohr didn't end the debate by observing that Einstein was using classical reasoning. I'm saying that wouldn't end the debate, because the debate wasn't about classicism versus modern physics; it was about realism versus the Copenhagen interpretation. (I'm a bit reluctant to classify Bohr as a positivist because I suspect that a fair number of pre-20th-century positivists would disown Copenhagen; but Einstein's realism is indisputable, and a fair case could be made that Bohr was just accepting positivism without flinching).
Feb7-12, 12:01 AM   #8
Recognitions:
Gold Membership Gold Member
I think Bohr didn't said that because it wouldn't have been very effective. It would be like someone today who wants to argue that quantum fields should not be considered real saying "but you're using quantum mechanical reasoning" to claim they are. It is natural to use the reasoning of the best available theory, and to not want to let go of that reasoning until it is absolutely necessary. I believe that is all Einstein felt he was doing-- saying "I will continue to use classical reasoning until I'm convinced it doesn't work because that's what got us this far." He had some pretty specific ideas about what physics should be, and it served him well in relativity so it wasn't really that much of a stretch for him to do the same in quantum mechanics. It just turned out that quantum mechanics was yet another seed change in what we think physics is (as was Newton's laws when they came around). And for proponents of the Bohm interpretation, they still think highly classical reasoning is fully appropriate, they seem the closest to Einstein's values about what claims on reality a physics theory should make.
Feb7-12, 12:41 AM   #9
Ah now I'm getting your point (or at least more so). I agree that the bigger debate between Einstein and Bohr was about classicism versus modern physics, but restricting ourselves between their specific discussion about the UP and even more specifically concerning the said thought experiments, I don't see why "you're using classical reasoning" wouldn't be a valid counter-argument in this case. After all, Einstein is trying to prove QM wrong (with a specific example), but he's using non-QM reasoning; seems like a no-go.
@ Ken G:
I'm not sure if I'm following the analogue, possibly due to grammar? (I'm not trying to be hard-***!) Anyway, it would seem to me that if someone wants to find a flaw in a theory and proposes a thought experiment to explicitly show the flaw, certainly the thought experiment should use that theory, don't you agree? It seems quite straight-forward enough, but allow me to still propose an analogue of my own: it would be like someone trying to disprove relativity theory by using a galilean reasoning.
Fair enough, but do you (personally) believe that his arguments (restricting ourselves to the UP ones, the thought experiments we've both heard of) would carry any weight even if Bohr hadn't countered them the way he had? I can't think of anyone saying "yes", but on the other hand it's Einstein we're talking about here, so I just want to make sure I'm able to appreciate his points to the best of my ability. Do you understand my struggle?
I believe I disagree. Einstein is using the classical idea of conservation of momentum (and not statistically averaged by using the wave function). I don't think Bohmians do that?
Feb7-12, 01:14 AM   #10
Sorry - my comment was more of a general comment than anything else.
Feb7-12, 02:26 AM   #11
Indeed it is. One of the issues is that people think Einstein disagreed with QM - he didn't. In fact he wrote a forward to a standard book on QM written by David Bohm that he greatly admired and recommended the book to all physicists. He believed it was incomplete in the sense that classical mechanics is incomplete but within its domain of applicability was correct. He was the first advocate of the ensemble interpretation of QM which is the one I adhere to and now days standard textbooks such as Balentines use it exclusivity and explain its advantages over Copenhagen.
http://en.wikipedia.org/wiki/Ensemble_interpretation
'The attempt to conceive the quantum-theoretical description as the complete description of the individual systems leads to unnatural theoretical interpretations, which become immediately unnecessary if one accepts the interpretation that the description refers to ensembles of systems and not to individual systems.—Albert Einstein'
He disagreed with the Copenhagen interpretation because in trying to be a complete description it denied of an objective physical reality 'out there' independent of measurement - but he is hardly alone in that.
In modern times we now know that QM is basically a variant of bog standard probability theory to allow continuous transformations of what are called pure states:
http://arxiv.org/pdf/quant-ph/0111068v1.pdf
I suspect Einstein would approve - it does not provide what he wanted - but at least, like the ensemble interpretation, it gels with his views of what is going on.
Thanks
Bill
Feb7-12, 02:34 AM   #12
Bhobba, although your post in itself is interesting, I feel it's off-topic, so I just want to request others not to go into the subject of your post and to stay on-topic, thank you :)
Feb7-12, 02:52 AM   #13
Update
It seems some people believe that Bohr indeed could have used the "well you're using classical reasoning" argument but that he simply didn't because he wanted to play along with Einstein and show that there can also be found a fault in Einstein's reasoning, without necessarily believing Einstein's argument held much weight as it stood.
I strongly disagree and to back this up I want to quote Leon Rosenfeld, describing Bohr's initial reaction to Einstein's 2nd thought experiment (the photon in the box one)
It was quite shocking for Bohr [...] He did not see the solution at once. During the whole evening he was extremely unhappy, going from one to the other, trying to persuade them that it couldn't be true, that it would be the end of physics if Einstein were right
This clearly shows that Bohr thought Einstein's reasoning to be very valid, in the sense that he had no objection to using (for example) the conservation of momentum the way he did. Does anybody understand why? This is the core of my question.
Feb7-12, 03:04 AM   #14
UpdateThis clearly shows that Bohr thought Einstein's reasoning to be very valid, in the sense that he had no objection to using (for example) the conservation of momentum the way he did. Does anybody understand why? This is the core of my question.
Maybe, and this is just a guess, guys like Heisenberg had given similar semi classical reasoning in explaining the HUP to give it pictorial vividness. It follows very easily from the math of QM but in order for physicists to picture it they resorted to classical like 'analogies'.
Thanks
Bill
Feb7-12, 03:15 AM   #15
Recognitions:
I'd add this. Realism is indisputable because it is non-operational (faith vs empirical evidence). One often hears the comparison made between "Young Einstein" and "Old Einstein". Einstein's discovery of SR and GR, as seen in his early expositions, followed from the adoption of an operational re-interpretation of the meaning of space and esp. time. e.g. "Time is what we read off clocks, distance what we measure with measuring rods". This operational approach allowed him to explore the question of how to know if distant clocks are measuring synchronous times and thence to whether that even had absolute meaning.
Quantum theory can be understood in an analogous way, by being totally operational with regard to the act of measurement and meaning of "state" one is led to the question of its meaning between acts of measurement and its relativization.
But once this operational thinking leads to GR and once one formulates the most beautiful geometric model with space-time treated as a curved Riemannian manifold, (a "classical" reality model) I believe Einstein lost his youthful appreciation of operationalism. GR was so successful and the visualization of it in terms of a curved space-time manifold so compelling that it is difficult not to take the model for reality. (A problem, I believe with today's attempts to "quantize space-time" as if it were a real object.)
In short applying GR via differential geometry was a distinct conceptual practice with a distinct mode of thinking to synthesizing it in the first place.
I believe this turned Einstein into a more conservative realist who was unable to apply the same operationalism as it gets applied in to the relativization of state in QM.
That's just my opinion, of course, and colored by my understanding of QM and appreciation of "the" CI. But one my wonder if Bohr, with the advantage of our hindsight and perspective, might have been able to convince Einstein by expressing it in such terms.
Feb7-12, 03:35 AM   #16
Recognitions:
For the record, it was on-topic -- in the sense that your original post seems to be premised on a partial misunderstanding of what the Bohr-Einstein debate was about, which Bhobba tried to clarify.
(I was about to post something similar to what Bhobba said in post #11, but he got in first. :-)
Feb7-12, 07:47 AM   #17
Quote by bhobba View Post
Thanks
Bill
I've heard that view many times before, but do you truly think that's convincing? The UP they are discussing so vividly seems to be of a different nature than the one we're nowadays proving in our books, but more importantly if they were just discussing analogies, why would Bohr give it such grave importance? "it would be the end of physics if Einstein were right" does not sound like someone finding a hole in your analogy.
Quote by strangerep
I understand it can be read that way, but I honestly just think I asked a specific question unrelated to Einstein's general position (which I incidentally believe I already understood) as I nowhere made any statement about Einstein's general point of view, everything was case-specific. But anyway, as much as I don't want to derail this thread by talking about Einstein's realistic position, I also don't want to make it about whether or not I was clear that I didn't want to make it about Einstein's realistic position :p
@ jambaugh: please read post 12! You're telling me nothing new and are mainly discussing things which I've explicitly told (by now) that this thread is not about.
New Reply
Thread Tools
Similar Threads for: Bohr-Einstein debate: why did Bohr not simply say...
Thread Forum Replies
Reminiscences: 1976 interview with J.A.Wheeler (friend of Bohr and Einstein) History & Humanities 1
Bohr model atom problems involving allowed Bohr radii, energies, and energy levels. Introductory Physics Homework 4
Einstein and Bohr History & Humanities 1
bohr and einstein General Discussion 4
free will re: einstein/bohr General Discussion 59
