| New Reply |
Having trouble understanding variance of OLS estimator |
Share Thread | Thread Tools |
| Feb7-12, 12:42 AM | #1 |
So in computing the variance-covariance matrix for β-hat in an OLS model, we arrive at
VarCov(β-hat)=(σ_ε)^2E{[X'X]^-1} However, I'm incredulous as to how X is considered non-stochastic and how we can just eliminate the expectation sign and have VarCov(β-hat)=(σ_ε)^2[X'X]^-1 I'm accepting this to be true (since it's so written in the text) but I'm taking a leap of faith here: if this is true, the elements in the VarCov matrix are expressed in terms of sample statistics and are therefore stochastic. I thought that the variance of an estimator of a parameter, if consistent, should be a deterministic parameter itself and should not depend on the sample observations (besides sample size, n), such as the ones we see in using Cramer-Rao lower bound to determine efficiency. Likely I'm understanding something wrong here, any pointers would be greatly appreciated! |
| Feb7-12, 03:31 AM | #2 |
Recognitions:
You haven't clearly stated a mathematical question. Is X supposed to be the vector of independent variables? If so, they aren't considered to be stochastic if you compute the regression so it minimizes the least square error in predicting the dependent variables, which are "Y", by tradition. If you have data of the form (X,Y) and there are "errors" in both X and Y, you should use a "total least squares" model.
| Feb7-12, 03:37 AM | #3 |
Hey chevrox and welcome to the forums.
Like Stephen Tashi I am going wait for clarification of what your variables are but I did want to comment on one thing you said: |
| Feb8-12, 12:45 AM | #4 |
Thanks for the replies! Yes, X is the nxk matrix of explanatory variables such that y=Xβ+ε. I think I understand it now. Variables in X do not necessarily follow a stochastic process, and even if they do, since all variability of y is explained by ε in the model, the independent variables affect the dependent variable solely through their observed values rather than a range of distribution where those values could fall, and it is therefore considered non-stochastic. And meanwhile β-hat does not lose its consistency since E(β-hat)=β (which is possible only if X is non-stochastic) and Var(β-hat)→0 even though Var(β-hat) varies with sample.
| New Reply |
| Tags |
| linear regression |
| Thread Tools | |
Similar Threads for: Having trouble understanding variance of OLS estimator
| A little help understanding standard deviation & variance | Set Theory, Logic, Probability, Statistics | 5 | ||
| Estimator for variance when sampling without replacement | Calculus & Beyond Homework | 5 | ||
| expected value nd variance of mean estimator | Calculus & Beyond Homework | 6 | ||
| Why is the variance of the Parzen density estimator infinite? | Set Theory, Logic, Probability, Statistics | 1 | ||
| unbiased estimator of variance | Set Theory, Logic, Probability, Statistics | 2 | ||
