Don't understand with what the question want
  • Thread starter Thread starter Sanosuke Sagara
The discussion revolves around a physics problem involving a square coil made from a wire, its dimensions, and its behavior in a magnetic field. Participants are trying to clarify the specifications of the coil and its implications for the problem at hand.
  • Participants are questioning the interpretation of the coil's dimensions, specifically whether the stated length applies to each side of the square or if there is a discrepancy in the problem's description. Some are exploring the implications of the coil having multiple turns.
The discussion is ongoing, with some participants expressing confusion about the problem's wording while others suggest that the original problem statement may be correct. There is a mix of interpretations being explored, and some guidance has been offered regarding the number of turns in the coil.
Participants are navigating potential inconsistencies in the problem statement, particularly concerning the dimensions of the coil and the total length of the wire used. There is uncertainty about how these factors affect the setup of the problem.
Sanosuke Sagara
A long piece wire of mass 0.1kg and length 4.0m is used to make a square coil 0.1m on a side.The coil is hinged along a horizontal side,carries a 3.4 A current,and is placed in a vertical magnetic field of mahitude 0.01 T.
(a)Determine the angle that the plane of the coil makes with the vertical when the coil is in equilibrium.
I want to know what is meant by the 'square coil 0.1m on a side' phrase ?Is it mean each length of the coil is 0.1m ? or only one length is 0.1m and the other end is 3.9m making the dimension of the coil is (3.9 x 0.1) ?
Thanks for anybody that spend sometime on this question .
Something is wrong in the question. Either it is .4 m long and a square .1 m x .1 m. or it is 4 m. long and a square 1 m x 1 m.
AM
Ok ,anyway thanks for your help in this question.Thanks.
I think there is no mistake in the problem. The square coil has 10 turns.
Each coil length = 4 X 0.1 = 0.4 m
If the coil has 10 turns, total length = 10 X 0.4 = 4 m
Gamma
Your assumption is right Gamma and I can calculate the angle made between the plane of the coil and magnetic field.
11K
