How Does the Rate of False Signals Change With Three Sensors?
The discussion focuses on calculating the rate of false signals generated by two and three sensors with noise rates R_{A}^{noise} and R_{B}^{noise}. For two sensors, the rate of false signals is defined as R_{AB}^{noise} = 2R_{A}^{noise}R_{B}^{noise}\tau. When introducing a third sensor, the participant attempts to derive the formula R_{ABC} but struggles with the integration limits and the correct formulation. The correct approach involves integrating the product of the noise rates across the defined time intervals.
  • Understanding of probability theory and integration
  • Familiarity with noise rates in sensor systems
  • Basic knowledge of calculus, specifically double integrals
  • Concept of time intervals in signal processing
  • Study the derivation of false signal rates in multi-sensor systems
  • Learn about the application of double integrals in probability calculations
  • Research noise reduction techniques in sensor networks
  • Explore advanced topics in signal processing, focusing on sensor fusion
Students and professionals in engineering, particularly those working with sensor networks, signal processing, and noise analysis.
McCoy13
Suppose you have two sensors with rates of noise [itex]R_{A}^{noise}[/itex] and [itex]R_{B}^{noise}[/itex]. Suppose an erroneous signal occurs if the two sensors have a noise trigger within time [itex]\tau[/itex] of each other. Show that the rate of false signals is [itex]R_{AB}^{noise}=2R_{A}^{noise}R_{B}^{noise}\tau[/itex]. How does this change if a third sensor is introduced?
N/A
I will now drop the noise superscripts for convenience. Also note that the rates above are constants, and do not vary in time.
The probability that each sensor has a false signal in a time dt is obviously R*dt. So the probability that they both fire ought to be [itex]R_{A}R_{B}dtds[/itex]. We are interested in number of counts per time, so we will need to take an integral to bring probability to counts and a time derivative to get a rate.
[tex]R_{AB}=\frac{d}{dt}\int^{\tau}_{-\tau}R_{A}R_{B}dsdt = R_{A}R_{B}\int^{\tau}_{-\tau}ds = R_{A}R_{B}2\tau[/tex]
So for three sensors I do the analogous thing, presuming I got the above right. Here's the catch - I'm not sure what do with the integral limits.
[tex]R_{ABC}=\frac{d}{dt}\int \int R_{A}R_{B}R_{C}dudsdt[/tex]
My only guess is that the first integral is integrated to the next integral's variable.
[tex]R_{ABC}=\frac{d}{dt}\int^{\tau}_{-\tau} \int^{s}_{-s} R_{A}R_{B}R_{C}dudsdt = R_{A}R_{B}R_{C}\frac{d}{dt}\int^{\tau}_{-\tau}2sdsdt = R_{A}R_{B}R_{C}[s^{2}]^{\tau}_{-\tau} = 0[/tex]
This is obviously not the correct answer. Any help would be appreciated.
Maybe I didn't really do the analogous thing. I still have 3 pure numbers with [itex]R_{A}dtR_{B}dsR_{C}du[/itex], so by dimensional analysis I still only need one integral and one derivative, but what happens to the remaining differential time?
  • · Replies 24 ·
