Laplace transform - step function
The problem involves finding the Laplace transform of a piecewise function defined as f(t) = 1 for 0 ≤ t ≤ 1 and f(t) = 0 for t > 1. The context is within the subject area of Laplace transforms and step functions.
  • Participants discuss the definition of the step function and its shifting properties. There are attempts to clarify the conditions under which the function is equal to 0 or 1, and questions arise about the correct interpretation of the discontinuous point in the function.
The discussion is ongoing, with participants exploring different interpretations of the step function and its application to the problem. Some guidance has been offered regarding the shifting of the step function, but there is no explicit consensus on the approach yet.
Participants are navigating the definitions and properties of the step function, particularly in relation to the specific values of the function at the boundaries of the defined intervals. There is a focus on ensuring clarity around the behavior of the function at the discontinuous point.
Pi Face
f(t)= 1 if 0≤t≤1 ; 0 is t>1
find the laplace transform
I know u(t)= 0 for t<0 and 1 for t≥0
I know I have to shift it and get
u_a(t)=u(t-a)= 1 if 0≤t≤a, 0 if a>1
am I even going the right way?
then I think I integrate it from 0 to inf with
∫e^(-st)u_a(t) dt = ?
not sure what to do from here
Pi Face said:
[I know I have to shift it and get
What?
I thought there was a step involving replacing the discontinuous point with a
There is, but your description doesn't make sense. When is ua(t) equal to 0 and when is it equal to 1?
f(t) is 0 when t>1 and 1 when it is between 0 and 1, inclusive.
so for ua(t) wouldn't I just replace the 1 with a?
I'm not following what you're getting at. Replace what 1 with a?
You replace the discontinuous point with a right? Which happens to be one in this problem because it has a value of 0 whe greater than 1 and a value of 1 when between 0 and 1. So the discontinuous point would be at 1? Which you replace with a?
You have it backwards. You don't replace 1 with a. You set a to 1, i.e., u1(t) = u(t-1). That's the step function shifted to the right by 1.
$$u_1(t) = u(t-1) = \begin{cases}
0 & t<1 \\
1 & t\ge 1
\end{cases}$$
