Register to reply
Problems with zheev
by Rositta
Tags: zheev
Share this thread:
Rositta
#1
Feb9-12, 08:02 AM
P: 13
I'm using zheev subroutine in a do loop (up to 2000 times) that contains other subroutines and functions. The matrix to diagonalize is only 5-by-5 however zheev gives the correct eigenvalues for only few cases even after reducing the number of times in the do loop. Any hint would be highly appreciated...
Phys.Org News Partner Science news on Phys.org
Law changed to allow 'unlocking' cellphones
Microsoft sues Samsung alleging contract breach
Best evidence yet for coronal heating theory detected by NASA sounding rocket
Mark44
#2
Feb9-12, 12:57 PM
Mentor
P: 21,214
Quote Quote by Rositta View Post
Without seeing your code, there's not we can do to help you diagnose the problem.
Rositta
#3
Feb10-12, 06:34 AM
P: 13
Quote Quote by Mark44 View Post
Sorry.. Here is the main programme:
=>program xggauss
IMPLICIT NONE
! declare variables for part1
integer:: nval,i,k0
integer,parameter::kf=20
real*8,parameter::pi=3.141592653589
real*8:: x1,x2,dx,func,ss,x,r,del
complex*8::sphshift
! declare variables for part2
real::vb,bb
real*8,dimension(1:kf)::eb,k,kk,perturb
complex*8,dimension(1:kf)::delta
real*8::Eval(5)
integer,parameter::LDA=5
complex*16,dimension(LDA,LDA)::Evec
parameter(vb=1.,bb=1.)
external func,sphshift
print*,'lower limit='
read*,x1
print*,'upper limit='
read*,x2
print*,'number of intervals='
read*,nval
dx=(x2-x1)/nval
write(*,'(f6.3,1x,a,t12,a,t23,a/)') x1,'to','qgauss','expected'
do 12 k0=1,kf
k(k0)=k0*0.001
eb(k0)=k(k0)**2
kk(k0)=sqrt(vb+eb(k0))
do 11 i=1,nval
x=x1+i*dx
call ggauss(func,kk(k0),x1,x,ss)
11 continue
perturb(k0)=(2*bb/kk(k0)**2)*(1/(14*sqrt(pi)))*ss
delta(k0)=sphshift(k(k0),kk(k0))
call eigvals(perturb(k0),sphshift(k(k0),kk(k0)),Eval,Evec)
write(*,'(1x,I5,1x,f6.4,1x,f10.8,2x,f10.8,2x,f15.13,2x,f15.13,(2x,f15.1 3,1X,f20.18))')k0,k(k0),kk(k0),eb(k0),ss,perturb(k0),delta(k0)
CALL PRINT_RMATRIX('Eigenvalues', 1, 5, Eval, 1 )
print*,'*************************************************************** *****************'
12 continue
end program xggauss
real*8 function func(x,r)
real*8:: x,r
func=x**4*((x*r)*((3/(x*r)**2-1)*(sin(x*r)/(x*r))-(3*cos(x*r)/(x*r)**2)))**2
end function func
complex*8 function sphshift(x,y)
real*8:: x,y,cb1,cb2,cb,db1,db2,db,del2,fb1,fb2
cb1=sin(x)*(4*x**2-9)+cos(x)*(9*x-x**3)
cb2=sin(x)*(9*x-x**3)-cos(x)*(4*x**2-9)
db1=sin(x)*(3-x**2)-3*x*cos(x)
db2=cos(x)*(3-x**2)+3*x*sin(x)
cb=db1*(sin(y)*(4*y**2-9)+cos(y)*(9*y-y**3))-cb1*(sin(y)*(3-y**2)-3*y*cos(y))
db=cb2*(sin(y)*(3-y**2)-3*y*cos(y))+db2*(sin(y)*(4*y**2-9)+cos(y)*(9*y-y**3))
del2=atan(-cb/db)
fb1=cos(del2)*sin(del2)/x
fb2=sin(del2)**2/x
sphshift=cmplx(fb1,fb2)
end function sphshift
and this is the subroutine I'm using to find the eigenvalues:
=>subroutine eigvals(perturb,sphshift,W,Q)
implicit none
real*8,intent(in)::perturb
!declare variable for zheev subroutine
integer::Info,Lwork
integer,parameter::m=5
integer,parameter::LDA=m
integer,parameter::Lwmax=100
complex*16,dimension(LDA,m),intent(out)::Q
complex*16,dimension(1:Lwmax)::Work
real*8,intent(inout)::W(m)
double precision::Rwork(3*m-2)
complex*8::sphshift
complex*16,dimension(m,m)::oct,ones
data oct/(1.,0.),(0.,0.),(0.,0.),(0.,0.),(5.,0.),(0.,0.),(-4.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),&
(0.,0.),(6.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(-4.,0.),(0.,0.),(5.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.)/,&
ones/(1.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.),(0.,0.),(0.,0.) ,(0.,0.),(0.,0.),&
(0.,0.),(1.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.),(0.,0.) ,(0,0.),(0.,0.),(0.,0.),(0.,0.),(1.,0.)/
integer::i,j
intrinsic int,min
do i=1,m
do j=1,m
Q(i,j)=perturb*oct(i,j)+sphshift*ones(i,j)
end do
end do
CALL ZHEEV('V', 'L', m, Q, LDA, W, WORK, LWORK, RWORK, INFO )
Lwork=min(LWMAX,int(WORK(1)))
IF(INFO.GT.0) THEN
WRITE(*,*)'The algorithm failed to compute eigenvalues.'
STOP
END IF
end subroutine eigvals
AlephZero
#4
Feb10-12, 02:51 PM
Engineering
Sci Advisor
HW Helper
Thanks
P: 6,967
Problems with zheev
I think you are trying to call ZHEEV to find the size of the work array, then call it again to solve the eigenproblem.
You need to set Lwork = -1 every time before the first call. Your code doesn't seem to set it to anything before the first call to ZHEEV. Most likely your code crashes "randomly" because Lwork eventually has a bad value.
Rositta
#5
Feb17-12, 04:53 AM
P: 13
Quote Quote by AlephZero View Post
Thaks a lot AlephZero. All the eigenvalues are calculated correctly now :)
Register to reply
Related Discussions
What makes putnam-style problems 'different' from other problems? Academic Guidance 3
Projectile Motion problems (don't want answers to problems) Calculus & Beyond Homework 1
Chesmistry 12|VSEPER Problems|Quick Problems Biology, Chemistry & Other Homework 1
Can someone double check to see if I did these problems correctly? E-Flux problems Introductory Physics Homework 3
