Finding the pH of a buffer solution when a strong acid is added
  • Thread starter Thread starter TheSwede
    Acid Buffer Ph
The discussion focuses on calculating the pH of a buffer solution containing 0.40 moles of propanoic acid and 0.50 moles of sodium propanate before and after the addition of a strong acid, HCl. The initial pH is calculated using the Henderson-Hasselbalch equation, yielding a pH of 4.75. When 3 milliliters of 2.0 M HCl is added, the concentrations of the weak acid and its conjugate base change, necessitating a reevaluation of the pH based on the new concentrations.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of weak acids and their conjugate bases
  • Familiarity with pKa and Ka values
  • Basic concepts of buffer solutions and their behavior with strong acids
  • Calculate the new concentrations of propanoic acid and sodium propanate after adding HCl
  • Reapply the Henderson-Hasselbalch equation to find the new pH
  • Explore the concept of buffer capacity and its limits
  • Study the effects of strong acids on various buffer systems
Chemistry students, educators, and laboratory technicians involved in acid-base chemistry and buffer solution analysis.
TheSwede
Three milliliters of a 2.0 M solution of HCL are added to 1 liter of buffer solution containing 0.40 moles of the weak acid, propanoic acid (Ka = 1.4 x 10-5) and .50 moles of its conjugate base, sodium propanate.
1) find the ph of the buffer solution
2) find the ph when the strong acid is added to the buffer solution
Henderson Hasselbach equation: pH = Pka + log( A- / HA)
1) to find the pKa -log(1.4 x 10-5) = 4.85
pH = 4.85 + log(.4/.5) = 4.75
is this correct?
2) clueless
What happens when you add a strong acid? Is there any reaction taking place? How does it change concentrations of propanate and its conjugate acid?
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 20 ·
