Advanced physics problems on electric fields.
The discussion centers on a physics problem involving a particle ray gun used by Secret Agent Jane Pond, where particles with a charge of -2e and mass of 50u are shot through a uniform electric field created by two charged sheets. The problem requires calculating the net electric field at the entry point in terms of charge density (σ) and permittivity of free space (ε0), determining which sheet the particles will strike, and finding the initial speed of the particles given specific parameters. The charge density is specified as σ=25 nC/m², and the final location of the particle ray is 5.0 cm from the entry edge of the sheet.
  • Understanding of electric fields and forces in physics
  • Familiarity with the concept of charge density (σ)
  • Knowledge of kinematic equations related to projectile motion
  • Basic grasp of particle physics, including charge and mass units
  • Calculate the net electric field between parallel charged sheets using the formula E = σ/ε0
  • Explore the effects of angle on electric field direction and particle trajectory
  • Investigate the kinematic equations to determine the initial velocity of charged particles
  • Study the principles of uniform electric fields and their applications in particle physics
Students and educators in physics, particularly those focusing on electromagnetism and particle dynamics, as well as professionals involved in experimental physics and engineering applications related to electric fields.
ohyahjohn
Secret Agent Jane Pond is testing out a new particle ray gun. She knows the particles in the ray have charge -2e and a mass of 50u. (u = atomic mass unit.) To determine the speed of the particles in the ray, Jane needs a region of uniform electric field. She takes two very large uniformly charged sheets with charge densities of ±σ , and arranges the sheets so that the positive sheet is horizontal and the negative sheet makes a 60° angle with the horizontal. She then shoots the particle ray through the region of space between the sheets, entering the region 1.0 mm vertically from the horizontal sheet and 4.0 mm horizontally to the side of the intersection point, with an initial velocity parallel to the intersection axis. (a) Find an expression for the net electric field at the entry point, ignoring edge effects. (i.e., you can treat the sheets as infinite.) Your answer should be in terms of σ and ε0. (b) Which sheet will the particle ray ultimately strike? Explain how you know. (c) Jane finds that the location where the ray hits the sheet is 5.0 cm from the entry edge of the sheet. If σ=25 nC/m2, what is the initial speed of the particles in the ray?
Welcome to PF.
In order for us to help you, you need to have an attempt at the problem or at least tell us about how you are thinking about it. That way we can tailor the assistance to what you actually need instead of guessing.
  • · Replies 26 ·
12K
