New Reply
Can I interchange CCFL bulbs between different laptops?
Share Thread Thread Tools
Feb13-12, 05:58 AM   #1
So I have an HP Pavilion DV2000 and an old Toshiba Satellite whose screens do not work any longer.
The Toshiba has a cracked backlight. The DV2000...well I'm not sure if it's the inverter or the backlight. I know the LCD panel works fine; I can see what's on the screen if I shine a very bright light up to it. I took it apart and readjusted things and found that the HP screen worked fine for about 20 minutes. Then it randomly died. And every once in a while, the screen works for a few minutes, and then dies. Lately it hasn't worked at all.
Anyways, I'd like to take the bulb out of the HP and put it in the Toshiba to see if the bulb is still good. It's been used for well under 50,000 hours, so I think it's okay, but I'm just wanting to be sure. The only problem is that the backlight plugs are different on the HP and Toshiba. These are not pictures of mine, but they will give you an idea:
http://www.iccfl.com/images/ccfl_con...re_2_pin_3.jpg
http://symlink.dk/projects/flatpanel/ccfl-connector.jpg
So I'm assuming the inverters are each putting out a different voltage. Or maybe they're not, I'm not sure. Anyways, I'm wondering if I could cut off the plug and solder the other one on, so I could just interchange them to see if it works or not.
Is this possible? Is it a good idea?
Any help is appreciated, thanks in advance!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Can I interchange CCFL bulbs between different laptops?
Thread Forum Replies
CCFL inverter question? Electrical Engineering 6
CCFL Angel Eyes Inverter Electrical Engineering 0
Interchange of limit operations Calculus & Beyond Homework 9
Can we interchange four probes terminals? Classical Physics 2
interchange of integrals and limits Calculus 4
