Does Clifford algebra solve both QFT and GR
The discussion revolves around the potential applications of Clifford algebra in both Quantum Field Theory (QFT) and General Relativity (GR). Participants explore whether a common algebraic framework could allow for a derivation of GR from QFT or vice versa, and the implications of using Clifford algebra, quaternions, and octonions in these contexts.
  • Some participants suggest that Clifford algebra may provide a unifying framework for both QFT and GR, questioning if it can derive one from the other.
  • Others express uncertainty about the validity of applying Clifford algebra, quaternions, and octonions in physics, seeking consensus on their fundamental importance.
  • There are inquiries about the specific roles of Clifford algebra in GR and its relationship with quaternions and octonions in the Standard Model (SM).
  • Some participants note that Clifford algebra is essential for understanding spinor representations and the Dirac equation, while quaternions and octonions may be less critical.
  • Questions arise regarding the connection between the algebraic structures and their applications in different physical theories, particularly whether they can be integrated or if they operate on fundamentally different objects.
  • References to literature and resources are shared, indicating a desire for further exploration of the topic.
  • Some participants speculate on the relationship between spin foam networks in Loop Quantum Gravity (LQG) and spinors derived from Clifford algebra, though details remain unclear.
Participants do not reach a consensus on the applicability or foundational status of Clifford algebra, quaternions, and octonions in physics. Multiple competing views and uncertainties remain regarding their interconnections and roles in QFT and GR.
The discussion highlights limitations in understanding the specific mathematical steps and assumptions underlying the use of these algebras in physics. There are unresolved questions about how these algebras interact and whether they can be reconciled within a unified framework.
friend
I noticed a few sources that seem to indicate that Clifford algebra may be used in both QFT and GR. I've seen where the Clifford algebra is a type of associative algebra that generalizes the real numbers, complex numbers, quaternions, and octonions, see Wikipedia on Clifford Algebra. And I've seen where the complex numbers, quaternions, and octernions can be used in the description for the U(1), SU(2), SU(3) symmetries of the Standard Model, see this article, and this book. However, I've also seen where the Clifford algebra can be used in an alternative description of differential geometry used in the formulation of GR, see this book for example.
So my question is does this common algebra allow us to derive GR in terms of QFT or visa versa? Or if we could justify the use of the complex numbers, quaternions, octonions, and the Clifford algebra by some other means, could we derive both QFT and GR from that common justification of the algebra? What more information or constraints would be needed to do so?
I'm trying to decide whether I should research the Clifford algebra and how it applies to physics. I'm looking to get a sense of how valid is the application of Clifford algebra in physics. Is there a consenses that Clifford algebra, quaternions, and octonions are indeed fundamental or at least have a valuable use?
If the use of these algebras is valid in physics, then I have to wonder... Since the Clifford algebra is used in differential geometry, and quaterions and octonions are used in the SM, then can the quaternions and octonions be used to contrain the Clifford algebra in such a way in differential geometry as to product GR if the SM is assumed? Or is it more the case that the Clifford algebra is used on the metric whereas the quaternion and octonions are used on wavefunctions, which is a totally different animal? Any insight would be appreciated. Thanks.
friend said:
I'm trying to decide whether I should research the Clifford algebra and how it applies to physics...QUOTE]
What a strange question! Of course Clifford (geometric) algebra does apply to physics! Just think about spinors, Dirac equation...
Yes, some people are using it as the basis of the SM. But I'm having trouble getting started with my studies of quaternions, octonions, and clifford algebra. My linear algebra and group theory is weak. Do you know of any easy introductions to quaternions, octonions, and clifford algebra?
So when they use the quaternions and octonions in the SM, do they use the algebra to establish commutation relation between fields? How is the Clifford algebra used in GR? Is it used on connection fields perhaps? Does it establish commutation relations, or perhaps the Bianchi identity, what? Thanks.
Clifford algebras are particularly necessary for understanding spinor representations and spin groups. Depending on what you're interested in studying, they could be important (a good knowledge of the mathematical underpinnings of SM and QFT will require knowledge of Clifford algebras). I'd say that quaternions (and octonions) are less important: quaternions offer an alternative to the tensor formulation of GR, and are not something I'd concern myself with on an initial read through.
I would certainly get up to speed on your linear algebra and group theory (in particular Lie groups and Lie algebras which are widespread in particle physics) before I'd worry about Clifford algebras and quaternions.
The problem is that I seem to have been able to justify the use of quaternions and octonions from purely logical reasons. And now I wonder if this is a road into physics. So I feel like I need to go from these hypercomplex numbers to SM physics. You seem to indicate that you can go from the SM to hypercomplex numbers. But can one go from hypercomplex numbers to the SM?
If with SM you mean standard model, then yes some parts of the Lagrangian are involving the Pauli matrices and you can consider that these matrices are a representation of the quaternions or of a Clifford algebra. See the theory of spinors by E. Cartan himself.
I hope it is allowed to propose a (commercial) link here but if you need a reference either type the words on google or go to the following link (but it is not the only possible one): https://www.amazon.com/dp/0486640701/?tag=pfamazon01-20
You get everything you need to beginn with and if you are patient, at the very end of the book, a part of the answer to your initial question.
Yes, the book is on its way. Thanks.
But from what I can tell from what I've seen on the Net, clifford algebra is used either for geometry or for the SM in the form of quaternions and octonions. What I don't see is anyone connecting the two. Is this because the algebra operates on two different objects that can't be connected in some way?
For example, is there a connection between spin foam networks of LQG and the spinors derived using clifford algebra?
It is far far far over my head and I cannot help you or explain details.
But I just guess that the answer is: some where yes.
Good luck
http://arxiv.org/pdf/1201.2120v1.pdf
Relevant References
For Clifford/Geometric Algebra the most relevant reference is -
"Geometric Algebra for Physicsts" by Doran and Lasenby
https://www.amazon.com/dp/0521715954/?tag=pfamazon01-20
Which covers (among other things) both the Dirac equation and the Gauge Theory of Gravity.
I have a set of notes based on Doran and Lasenby and symbolic software in python at
https://github.com/brombo/GA
What I'm reading so far is that the S0(1,3) symmetry of Lorentz invariance is a "double cover" for the SU(2) symmetry of the Standard Model. And I'm read other places that the spin of a particle is deeply connected to Lorentz invariance. Is this deep connection the double cover?
What does double cover mean anyway? Is this covered in the book you mention? Thanks.
Double Cover in Doran and Lasenby
It is mentioned in D&L. In GA rotations (in any dimension) are preformed with rotors which are scalars plus bivectors, R, with the condition that R*rev(R) = 1 (rev(R) is the reverse of R and * the geometric product). Then to rotate a vector, x, in the plane that R defines you evaluate
R*x*rev(R)
Since rev(-R) = -rev(R) if you replace R with -R you get the same result. This is the double cover. Note that R = exp((theta/2)*B) where B is a normalized bivector defining the plane of rotation. For the Lorentz transformation in Minkowski space if B is a spacelike plane if B**2 = -1 and
R = cos(theta/2)+sin(theta/2)*B
If the plane is timelike B**2 = 1 and
R = cosh(theta/2)+sinh(theta/2)*B
also note that rev(R) = exp(-(theta/2)*B). Multiple Lorentz transformation R1, R2 are evaluated with
R2*R1*x*rev(R1)*rev(R2)
and the geometric product * is the group operation.
Hello friend, there's been lots of good advice here so far. While playing with Clifford algebra is great fun, there's a risk of both overestimating and underestimating its importance in theoretical physics, and it's good to understand its context. Clifford algebra is useful in physics because the antisymmetric Clifford product between Clifford bivector elements is isomorphic to the Lie bracket between corresponding elements of the spin Lie algebra. This means Clifford algebra is hugely important in fundamental physics, but not a replacement for all of differential geometry. One still needs to understand Lie groups and differential forms, and then have even more fun with Clifford valued differential forms, specifically for describing connections (gauge fields). Even more specifically, gravity is well described using a spin connection, which is a spin(1,3)-valued 1-form, which can also be written as a Cl2(1,3)-valued 1-form, which usually acts on a Cl1(1,3)-valued gravitational frame as well as on spinors, which are defined using matrix representations of the spin group which correspond to matrix representations of Clifford algebras. Clifford algebra is also useful in the Standard Model because u(1)xsu(2)xsu(3) embeds in spin(10) (the Lie algebra of the Spin(10) GUT) or equivalently Cl2(10), with the SM gauge fields all parts of a spin(10)-valued 1-form, and the SM fermion multiplets living in 16 dimensional spinor representation spaces. There are, of course, other things one can do with Clifford algebras, including how this structure unifies in spin(11,3) and E8, but that's my opinion on their importance in fundamental physics. Hope you find that helpful.
Remind me again, U(1) is the symmetry of the Electromagnetic force and is represented by the dirac matrix? And SU(2) is the symmetry of the Weak force and is represented by the Pauli matix, and SU(3) is the symmetry of the Strong force and is represented by the what matix? Am I close?
  • · Replies 26 ·
  • · Replies 61 ·
11K
  • · Replies 27 ·
9K
  • · Replies 19 ·
