New Reply
Prob with NDSolve in Mathematica
Share Thread Thread Tools
Feb14-12, 09:28 AM   #1
How can I show the regular part of the solution of a differential equation, numerically solved with NDSolve, if there's a singularity on the curve ?
I know how to use NDSolve and show its solution, but Mathematica gives a bad curve after some point (singularity jumping). I don't want to show this part, just the regular curve BEFORE the singularity (which is occuring at t = %$&*).
More precisely, the curve function should be strictly positive : a[t] > 0. The NDSolve should stop the resolution if a <= 0. I added the command StoppingTest -> (a[t] < 0.001) or StoppingTest -> (a[t] <= 0) but it doesn't work. I'm still getting wrong curve parts with a[t] < 0.
Any idea ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb14-12, 11:13 AM   #2
Recognitions:
Gold Membership Gold Member
Why don't you just solve over the interval you're solving over now, but only plot it over the interval where it's positive?
Feb14-12, 12:25 PM   #3
Duh ! Because I don't know in advance what are the singularities !
There are two singularities on the curve, and I need to plot the regular part between them. There's no way I can know in advance the exact values of the singularities.
Feb14-12, 12:40 PM   #4
Try using Sow and Reap inside the NDSolve, and only Sow when the answer meets your criterion, as in the attached notebook.
Feb14-12, 12:56 PM   #5
Quote by phyzguy View Post
Very good trick ! Thanks a lot for that info !
However, I found the right solution to my problem : I just have to define the x values at which the curve y[x] blows away, like this :
Code:
Xmin := (y /. Curve)[[1]][[1]][[1]][[1]]
Xmax := (y /. Curve)[[1]][[1]][[1]][[2]]
Then, I plot the curve between these two values.
Feb14-12, 03:27 PM   #6
Recognitions:
I don't see how that's different than what I suggested.. but glad it worked for you
Feb14-12, 04:27 PM   #7
Quote by kai_sikorski View Post
Actually, it's exactly what you suggested. I just wasn't able to see how to implement it at first.
New Reply
Thread Tools
Similar Threads for: Prob with NDSolve in Mathematica
Thread Forum Replies
problem in NDSolve in mathematica Math & Science Software 5
NDSolve in mathematica Differential Equations 6
Mathematica NDSolve Differential Equations 2
Mathematica NDSolve Math & Science Software 1
Mathematica: ODE, NDSolve Math & Science Software 0
