New Reply
experimental uncertainty
Share Thread Thread Tools
Feb15-12, 01:16 AM   #1
hi, just a simple question
i have a linear graph y=mx+c
lets say my y values have an uncertainty of ±1 . my x values don't have uncertainties.
so what will my gradient's uncertainty be?
PS: can i just use the linear least square fit function from microsoft excel? do they calculate the same uncertainty?i.e is the standard deviation from this method, the same as the uncertainty that i am going to calculate as per above?
thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Feb15-12, 04:25 AM   #2
Can you simply display your values graphically, along with the error bars in the Y values and then see the variation in M that will fit within the 'envelope'?
Edit: is M held to a single value throughout the range? Or is it allowed to vary with X?
Feb15-12, 06:08 AM   #3
The uncertainty in the gradient is characterised by its standard error which Excel's LINEST function can provide using INDEX(LINEST(known_y's, known_x's, const, TRUE), 2,1). Given the standard error you can calculate confidence limits for the gradient in the same way as you presumably have for the data points in order to make the (statistically meaningless) statement that the 'y values have an uncertainty of ±1'. Note that the standard errors in m and c are in general more closely linked to the range in the x values than the errors in the y values.
To correctly interpret the regression statistics I think you should do some reading around the subject: Anscombe's quartet is IMHO a good start to understand some of the limitations of linear regression and the importance of graphical analysis.
Feb15-12, 06:20 AM   #4
Thanks for that link, MrAnchovy ! I have not seen that before. An unequivocal demonstration in the power of graphics & the human eye-brain.
Feb15-12, 07:25 AM   #5
wow, i didn't expect it to be this complicated? i don't think i am at your levels :(
i mean
lets say for my y-values, they are measurements of length of an object.
the uncertainty is say ±1cm.
so if i do a plot of length against anything(no uncertainty in x), then what will my gradient's uncertainty be?
for grad = y/x
so (σgrad / grad)2 = (σy / y)2 + (σx / x)2 ??? is it just like that?
is this uncertainty propagation? my notes says its just like that?
so since i don't have x uncertainties, i end up with
σgrad / grad = σy / y ?
but thats weird, it says every σgrad is different, because the value σy / y * grad is different for every y value....
Feb15-12, 07:39 AM   #6
Recognitions:
Gold Membership Gold Member
(Actually, now that I look at it, I'm not sure this answers your question at all. You've just been given a liner equation, and an uncertainty... Usually linear equations are accompanied by a correlation coefficient, not an uncertainty. )
I was asking some questions along this line some months ago
http://www.physicsforums.com/showthread.php?t=525091
The main thing that ought to be distinguished is systematic errors and random errors. You might not have any "random error" in your x-values, because you are measuring the same x-value in the same way, and getting the same result.
However, there may be a systematic error in your measurement of your x-value.
A quick google search gave me this article which gives some more detail:
http://www.ece.rochester.edu/courses...ncertainty.pdf
I'm not entirely certain how to account for possible systematic errors... You can really only account for systematic errors you KNOW are present.
Feb15-12, 08:54 AM   #7
Ah, I think you are talking about two different things here.
Experimental uncertainty refers to data that are subject to inaccuracy due to one or many random variables affecting the measurement of a quantity. Using certain assumptions, regression analysis can be used to determine the parameters of a 'line of best fit', including the standard errors in these parameters. This analysis in not simple and I have given some hints as to where to start.
Error propogation refers to data that are imprecise due to some limitation of the method used to measure (or record) a quantity. For instance an error of ±1cm would be produced by a ruler marked at 2cm intervals if you were unable to interpolate between markings.
In this case the analysis is fairly simple. The errors in y can be characterised by y = y' + ε where y is the true value of y, y' is the observed value and ε is the error (in this case, -1cm ≤ ε ≤ 1cm).
Taking y = mx + c, we have y' + ε = mx + c and y' = m'x + c where y' are the observed values of y and m' is the observed gradient. These give m' = m + ε / x. So the error in the gradient is 1cm divided by x.
Note that the formula σy / y implies that the precision is proportional to y rather than constant; a similar analysis can be performed.
For imprecise measurements the simplest way to determine the minimum and maximum gradients that fit the data is as gmax137 says to draw a graph with error bars and plot the steepest/shallowest lines that pass through each bar.
Feb15-12, 10:03 PM   #8
but if the grad error is m' = m + ε / x , then wouldn't it mean that for every x, i have a new m'?
lets say i am given x values as 10,20,30,40,50
then wouldn't my m' keep changing for different x? issn't that weird?
i didn't measure x by the way, those values were given.
but now that you guys talk about error propagation vs uncertainty, i realise that what i am talking about issn't exactly error propgation?
i think i am talking about confidence limits? it's not about systematic or maybe random errors.
i think it's more about human error.
lets say i want to determine the angle of a polarizer which produces the brightest emitted light.
but my eyes tells me the brightest light is over a range of angles. i can't pinpoint the angle that is....
so over a range of angles, say 1 degree. so that is my uncertainty in y.
so with x fixed/given, how will the gradient's error/uncertainty work out?
for that matter, is this called uncertainty or error propagation? or is it a human judgement error?
Feb16-12, 07:16 AM   #9
Recognitions:
Quote by quietrain View Post
Did they give you any y-values?
Let's say you have (10,y(10)), (20,y(20)), (30,y(30)), (40,y(40))
You know your x-values with perfect certainty, but your y-values are only known to an uncertainty of +/- 1. So you could calculate, one slope by adding 1 to your y-value on the right, and subtracting 1 from your y-value to the left.
[tex]\frac{\Delta y}{\Delta x}=\frac{(y(40)+1)-(y(10)-1)}{40-10}[/tex]
Then calculate another slope, similarly, by subtracting 1 from your y-value on the right, and adding 1 to your y-value on the left.
Well, I'm troubled whenever there seem to be several ideas which are not carefully distinguished. As near as I can tell, we are dealing with many different concepts here:
Precision uncertainty: If you have a meter marked in millimeters, you can make a guess down to the nearest 10th of a millimeter, but you should make a note that your scale is not as precise as that.
Experimental uncertainty: If you perform several trials measuring the same quantity, getting slightly different values each time, you can use statistics to estimate the uncertainty.
Population uncertainty: If you perform several trials measuring different quantities which you expect to be near each other, but are not necessarily exactly the same.
I'm not sure, but I think what you are looking at is a population uncertainty. Each pinpoint of light represents its own trial. Each trial interacted with a different point on the screen. And on average, those pinpoints land at the center of the light.
No, I don't think it is human judgement error, because the light beam really did not land at a point, but in a spread.
Feb16-12, 09:17 AM   #10
Yes it would, no it isn't weird because to get the value of y you multiply the gradient by the value of x: if the maximum error in the gradient were constant then the maximum error in y would increase proportionately to x whereas you said that the maximum error was a constant 1cm.
But it's probably not very relevant either - this is probably more helpful:
Estimate the true slope m by drawing a line through two points (x1, y'1) and (x2, y'2).
We have m' = (y'2 - y'1) / (x2 - x1). Inserting the precision errors, we get
m' = (y2 + ε2 - y1 - ε1) / (x2 - x1) = (y2 - y1) / (x2 - x1) + (ε21) / (x2 - x1) = m + 2ε / (x2 - x1).
So with your example and using the two extremes of x, the precision error in the gradient m' - m = 2 x 1cm / (50xunit - 10xunit) = 0.05cm.xunit-1
Well in that case you can't make a statement like 'the error in y is ±1cm', and what's more you don't need to, but I am afraid the answer is as I said in my first post, not simple.
Fitting a straight line to a data set analytically is called linear regression and the most common form is least squares fitting. If you scroll to the bottom of that page you will see expressions for the standard errors (equivalent to the standard deviation from which you can derive confidence limits) in the intercept a and the gradient b.
I don't know of any simpler way to show this I am afraid.
Feb17-12, 11:19 PM   #11
wow... ok thanks guys!
New Reply
Thread Tools
Similar Threads for: experimental uncertainty
Thread Forum Replies
Experimental test of the Uncertainty principle Quantum Physics 15
A question about uncertainty using a regression line and experimental data Introductory Physics Homework 1
Standard Deviation not equal to experimental uncertainty? Set Theory, Logic, Probability, Statistics 5
On the uncertainty principle for photons. An experimental counter example?? General Physics 42
Experimental uncertainty Advanced Physics Homework 1
