| New Reply |
Lamp Hanging in an Elevator |
Share Thread | Thread Tools |
| Feb15-12, 12:33 PM | #1 |
A lamp hangs vertically from a cord in a descending elevator that decelerates at 1.6 m/s2. (a) If the tension in the cord is 92 N, what is the lamp's mass? (b) What is the cord's tension when the elevator ascends with an upward acceleration of 1.6 m/s2? 2. Relevant equations F=ma 3. The attempt at a solution a) using M for mass, so as not to confuse it with 'm' for meters F(net)=M*a, T-F(gravity) = M*a 92N - M*(9.8 * m/s^2) = M*(-1.6 * m/s^2) 9.8*M - 1.6 M = 92 kg M = 11 kg b) T - (11 kg)*(9.8 m/s^2) = (11 kg)*(1.6 m/s^2) T = 18N + 110N T = 128N Both of my answers are wrong. Where am I going wrong in my thought process? |
| Feb15-12, 12:39 PM | #2 |
Always look at your equation from a common sense perspective. You have an elevator that is going down and slowing its descent. That tells me that if you are looking at tension in the cord that suspends it and the acceleration terms are on the same side of the equation, they had better have the same sign so that they will add together in a positive manner to increase tension.
| Feb15-12, 12:54 PM | #3 |
In part a) the elevator is decelerating downwards, so I made it negative. In part b) the elevator is accelerating upwards, so I made it positive. My thought process was:
Upwards (positive) vectors: Tension T Downwards (negative) vectors: M*Gravity acceleration = 1.6 (part b only) deceleration = -1.6 (part a only) I'm sorry, but I'm not entirely sure what you're trying to tell me. |
| Feb15-12, 12:59 PM | #4 |
Above is your equation. If you move the second term on the LHS to the RHS you get 92N = M*(9.8 * m/s^2) + M*(-1.6 * m/s^2) As you can see, they don't have the same sign. Since the elevator is slowing and going down, the tension (which is due to weight and acceleration) must get greater. How can it with your signs being different? |
| Feb15-12, 01:01 PM | #5 |
So I don't need to negate the acceleration even though it's decelerating, because it's not an actual force vector acting upon the lamp? I removed the (-) and my answer is correct now (thank you!), but I just want to understand the 'why' so I can not make this mistake again.
| Feb15-12, 01:27 PM | #6 |
Draw a free body diagram of the lamp (descening elevator) calling it M for its mass. There are several forces on it. Use arrows to denote their direction.
First is its weight; the arrow should be down. Section is the tension of cord; arrow should be up. Third is the acceleration force due to its slowing down. Because the acceleration is upward (slowing down), the force is in the opposite direction which is down. So summing forces and setting to zero with up being positive you have T - W - M*a = 0 where W and M*a are > 0. Always look at your equation and see if it makes good sense to you. |
| New Reply |
| Tags |
| acceleration, deceleration, elevator, force, lamp |
| Thread Tools | |
Similar Threads for: Lamp Hanging in an Elevator
| What happens to a lamp in series if lamp in parallel is broken? | Introductory Physics Homework | 12 | ||
| LED lamp | Electrical Engineering | 1 | ||
| Lamp hanging in a elevator | Introductory Physics Homework | 2 | ||
| dynamo lamp | General Physics | 4 | ||
| Lamp filament | Introductory Physics Homework | 8 | ||
