Electric field by a current carrying wire
The discussion revolves around the relationship between electric fields and current-carrying wires, exploring whether a wire carrying current induces an electric field and the implications of net charge within the wire.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants inquire about the existence of an electric field around a current-carrying wire and the rules for determining its direction. Questions arise regarding the net charge of the wire and its implications for electric fields. Some participants explore the relationship between constant current and magnetic fields, while others question the definitions of static and constant currents.
The discussion is active, with participants offering insights related to Gauss' law and the conditions under which an electric field may or may not exist. Multiple interpretations of the concepts are being explored, particularly regarding net charge and its effect on electric fields.
Participants are navigating assumptions about charge distributions within the wire and the definitions of current types, which may influence their understanding of the electric field's behavior.
jaobyccdee
Aside from magnetic field, Does a wire carrying current induce also an electric field? If yes, what rule should i use to find its direction?
Does a wire carrying a current have a net electric charge? What do you think?
Yes, so negative charges go one way, and positive charges go another direction. Isn't it?
The picture is usually that negative charges (the electrons) go one way and the positive charges (the atoms that have lost an electron) are fixed in a metal. But there's no reason to assume there are more of one than the other. If there is a net charge then you can't compute it from the current. No, there is no electric field that you can figure out from just knowing the current.
1. If there are the same number of positive charge and negative charge, then there's no net charge, and thus no electric field?
2. Can i say since a constant current has a magnetic field that doesn't change, so an electric field is not induced?
3. If the number of positive charge and negative charge are not the same, there is a net charge, then is there an electric field?
4. does a static current same as a constant current?
Thanks a lot!
Thanks a lot!
1. That's what Gauss' law would say. 2. A constant current creates a constant magnetic field - but that's not why the electric field is zero. 3. If the wire has a net charge, there will be an electric field. 4. I don't know what "static current" means - the only way I can think of the interpret it is "constant current".
