Carnot Efficiency vs Rankine Efficiency
  • Thread starter Thread starter mm391
    Carnot Efficiency
The Ideal Carnot Cycle is more efficient than the Rankine Cycle due to its theoretical foundation, which assumes 100% isentropic efficiency. However, the Rankine Cycle is preferred in practical applications because it effectively manages the challenges of wet steam and the complexities of pump operation with a mixture of steam and water. The limitations of the Carnot Cycle, particularly its reliance on ideal conditions, make the Rankine Cycle a more viable option for real-world energy systems.
  • Understanding of thermodynamic cycles, specifically Carnot and Rankine cycles.
  • Familiarity with isentropic processes and their implications in thermodynamics.
  • Knowledge of steam properties, including wet steam and its effects on turbine performance.
  • Basic principles of heat transfer and energy conversion in thermal systems.
  • Research the thermodynamic principles governing the Carnot Cycle and its efficiency calculations.
  • Explore the Rankine Cycle's practical applications in power generation and its operational parameters.
  • Study the impact of wet steam on turbine efficiency and methods to mitigate its effects.
  • Investigate advancements in turbine technology that aim to improve isentropic efficiency in real-world applications.
Students and professionals in mechanical engineering, energy systems engineers, and anyone involved in the design and optimization of thermal power plants.
mm391
Hi,
Given value of top and bottom temperatures can anyone explain why the Ideal Carnot Cycle is more efficient than the Rankine cycle but why the Rankine is the preferred model? I know that in the Carnot the pump would have to be able to deal with a mixture of steam and water and the turbine would have to be able to deal with wet steam (which is obviously not good).
Thanks
The Rankine cycle is practicable for the same reasons you stated.
Carnot cycle also assumes a 100% isentropic turbine, which is not achievable in reality.
