What is the Center of a Clifford Algebra of Order 2^n?
The center of a Clifford algebra of order 2^n is definitively established as having an order of 1 when n is even and an order of 2 when n is odd. This conclusion is derived from the properties of the basis elements, specifically that only the unit element γ_0 commutes with all other bases for even n, while both γ_0 and γ_{1,2,...,n} commute for odd n. The proof relies on the invertibility of basis elements and their commutation relations, confirming that linear combinations of non-commuting bases cannot span the center.
  • Understanding of Clifford algebra and its properties
  • Familiarity with the Kronecker Delta symbol and its application
  • Knowledge of commutation and anti-commutation relations
  • Basic linear algebra concepts, particularly regarding invertible elements
  • Study the properties of Clifford algebras in greater detail
  • Explore the implications of invertibility in algebraic structures
  • Learn about the applications of Clifford algebras in physics and geometry
  • Investigate alternative proofs for the center of Clifford algebras
This discussion is beneficial for mathematicians, physicists, and students studying algebraic structures, particularly those interested in the properties and applications of Clifford algebras.
sunjin09
Show that the center of a Clifford algebra of order 2^n is of order 1 if n is even, and 2 if n is odd
the center of an algebra is the subalgebra that commutes with all elements
Clifford algebra of 2^n is defined as being spanned by the bases
[itex]\gamma_0,\gamma_1,...\gamma_n[/itex]
where [itex]\gamma_0[/itex] is the unit element, as well as
[itex]\gamma_{\{n_k\}}=\Pi_{n_k}\gamma_{n_k}[/itex]
where [itex]1\le n_k\le n[/itex], and the mutiplication rule is
[itex]\gamma_u\gamma_v+\gamma_v\gamma_u=2\delta_{u,v} \gamma_0[/itex]
where [itex]\delta[/itex] is the Kronecker Delta symbol
I was able to show that for n even, only [itex]\gamma_0[/itex] commutes with all the other bases
and for n odd, only [itex]\gamma_0[/itex] and [itex]\gamma_{\{1,2,...,n\}}[/itex] commutes with all the other bases, but
how can I know that the center is spanned by the bases that commutes with
all the other bases?
In other words, how do I know that no linear combinations of
non-commuting bases commutes to all bases?
I finally figured it out. Two things need to be realized:
1.All the basis elements are invertible
2.Any pair of the basis elements either commute with each other or anti-commute with each other;
These may be verified fairly easily from the definition.
Now if x is in the center, x must commute with all the basis elements. For any basis element γ, x may be
written as x=x1+x2, where x1γ=γx1 and x2γ=-γx2; since xγ=γx, we have x2γ=0; since γ is invertible, x2=0;
since x2 which depends on γ equals 0 for all γ, x must contain only components that commutes with all basis,
i.e., γ0 and possibly γ{1,2,...,n}, qed.
fairly straightforward, it feels good to know the answer. Anyone has a simpler proof?
  • · Replies 25 ·
  • · Replies 26 ·
