Plotting y''[x] vs. y[x] in Mathematica with NDSolve
  • Context: Mathematica
  • Thread starter Thread starter Niles
    Mathematica
The discussion revolves around plotting the second derivative of a function against the function itself using Mathematica, specifically in the context of solving a differential equation with NDSolve. Participants explore methods for visualizing the relationship between y''[x] and y[x] while addressing issues related to plot ranges.
  • One participant describes a method to plot y''[x] against y[x] using ParametricPlot after solving a differential equation with NDSolve.
  • Another participant expresses a concern about the inability to set independent ranges for the x and y axes in the parametric plot.
  • A later reply suggests that using PlotRange -> {{0, 10}, {0, 5}} successfully allows for independent control of the ranges.
Participants appear to agree on the method for plotting y''[x] against y[x], but there is a brief discussion regarding the control of plot ranges, which is resolved with a suggested solution.
The discussion does not delve into the assumptions or limitations of the differential equation being solved or the specific behavior of the solutions over the defined range.
Users of Mathematica interested in plotting solutions to differential equations and those looking for techniques to manipulate plot ranges in parametric plots may find this discussion beneficial.
Niles
Hi
Say I solve the following differential equation in Mathematica:
Code:
s = NDSolve[{y''[x] + Sin[y[x]] y[x] == 0, y[0] == 1, y'[0] == 0}, y, {x, 0, 30}]
Plot[Evaluate[{y[x], y'[x], y''[x]} /. s], {x, 0, 30}, PlotStyle -> Automatic]
The last line plots the solutions vs. x, but how can I plot e.g. y''[x] vs. y[x]?
Niles.
ParametricPlot[Evaluate[{y[x], y''[x]} /. s], {x, 0, 30}]
Hi
Thanks for that. Whenever I try and alter the PlotRange, it changes both x and y. I guess that is reasonable, since it is a parametric plot. But is there any way for me to determine the range of x and y independently?Niles.
PlotRange -> {{0, 10}, {0, 5}} works. Thanks!
