Quadrilaterals using Geometer's Sketchpad (Thumbnail Included)
  • Thread starter Thread starter luke8ball
The discussion revolves around the construction and properties of quadrilaterals using Geometer's Sketchpad. Participants are exploring the types of quadrilaterals that can be formed based on specific geometric constraints and relationships between points and circles.
  • Participants discuss various types of quadrilaterals, including squares, rectangles, rhombuses, parallelograms, kites, and trapezoids. There is an exploration of the conditions under which these shapes can be formed and whether certain shapes, like non-isosceles trapezoids, can exist within the given setup.
The discussion is active, with participants sharing their thoughts on the types of quadrilaterals that can be formed and questioning the implications of symmetry and side lengths. Some guidance has been offered regarding the limitations of the shapes that can be created, but there is no explicit consensus on which quadrilaterals cannot be formed.
Participants are working within the constraints of using Geometer's Sketchpad and the specific geometric setup involving points A, B, C, and D, as well as the properties of the circles drawn. There is an ongoing examination of the implications of these constraints on the types of quadrilaterals that can be constructed.
luke8ball
Hi Guys! I've attached a picture of the setup if you don't have Geometer's Sketchpad software. I honestly have no idea where to begin with this problem, as I've been staring at it for hours. Nevertheless, I've still put some thoughts down on what I think I should do.
Use Geometer’s Sketchpad and draw points A, B, C (not all three are collinear).
Construct segments AC and BC.
Draw circle with center A and radius AC
Draw circle with Center B and radius BC
Label the other intersection of the circles D.
Draw segments BD and AD.
a. Drag point A, B, C, or D to change the shape of ABCD. What types of quadrilaterals can be formed? Explain.b. Are there types of quadrilaterals that cannot be formed? List and explain.
Square – Yes. If the two circles have radii of the same length, and if you adjust points C and D accordingly, you can have all 90° angles.
Rectangle – You can have a rectangle with all equal sides, but you can’t have a rectangle that isn’t a square, as the adjacent sides are always radii of the same circle, and cannot be different lengths.
Rhombus – You can have a rhombus because you can have a square, and you could just adjust the angles if you wanted a rhombus that wasn’t a square?
Parallelogram – You can have a parallelogram, but it has to be a rhombus as well, because adjacent sides must be equal.
Kite – You can certainly have a kite, as the pairs of adjacent sides (radii) will always be equal.
Any hints would be truly appreciated; I feel like an idiot staring at this problem in Geometer's Sketchpad.
All quadrilaterals formed must be symmetric about AB.
You can't create quadrilaterals that have 3 unequal sides or its sides crossed.
Thanks for the response!
So out of the list I've given, there are any of those that specifically can't be formed?
Does this also imply that a trapezoid must be an isosceles trapezoid?
The only trapezium can be formed is a square.
21K
