Calculate Power Usage using device specs
  • Thread starter Thread starter paulie walnut
    Device Power
The discussion revolves around calculating the power usage of a motor controlled by a variable speed drive, specifically focusing on the relationship between the motor's RPM and its power consumption based on its specifications.
  • One participant suggests that knowing the RPM alone is insufficient for calculating power usage and emphasizes the need for additional motor specifications such as wattage and volt-amps.
  • Another participant points out that the mechanical load attached to the motor influences power demand, indicating that different loads (e.g., fan vs. elevator) will affect power usage at varying RPMs.
  • A participant mentions that the load on the motor will be minimal due to a disc rotating on a shaft and expresses hope to calculate power usage by using the motor's specifications.
  • Another reply clarifies that even if a motor specification indicates a maximum power of 10KW at 1800 RPM, it does not imply that the motor will always consume that amount of power, as it depends on the actual load and operational conditions.
Participants generally agree that additional specifications beyond RPM are necessary for accurate power calculations, but there is disagreement regarding the significance of the load on power consumption and how it relates to the motor's specifications.
The discussion highlights the importance of understanding the relationship between motor specifications, load conditions, and power usage, but does not resolve the complexities involved in these calculations.
paulie walnut
Hi there!
I'm working on a project that involves the operation of a variable speed drive controlling a motor. I'm wondering if it is possible to calculate the power usage of the motor if the rpm of the motor is known. I'm not very knowledgeable when it comes to matters electrical but I thought it may be possible by calculating power use by making use of the motor specifications.
Can anyone point me in the right direction?
Thanks in advance
P
You need to know the specs for the motor such as watt and volt-amps. RPM is not enough information. Horsepower will give a lower limit but not the maximum power.
i think it depends on the mechanical load attached to the motor...
a fan or pump load will demand different power vs rpm than an elevator would.
Well the motor will have a disc rotating on a shaft so the load will be almost insignificant I think. I have the spec's of the motor so I had hoped to be able to "work backwards" using this info and calculate the power usage.
"Well the motor will have a disc rotating on a shaft so the load will be almost insignificant"
In that case the power consumption will be almost insignificant, just because a motor spec says 10KW at 1800 RPM doesn't mean that it will always use that 10 KW, the 10 KW is the maximum it is capable of.
  • · Replies 74 ·
11K
