Can Electrons and Photons Really Move by Jumping?
  • Context: Graduate
  • Thread starter Thread starter Alp_Oztek
    Light
The discussion centers around the concept of electrons and photons moving by "jumping," which the original poster describes as disappearing from one location and instantly appearing in another. This idea is explored in the context of quantum mechanics and the nature of light and particles, with participants providing various perspectives on the validity and implications of this hypothesis.
  • The original poster suggests that the movement of electrons and photons can be conceptualized as "jumping," with a relationship to energy/mass ratios.
  • Some participants argue against the idea of particles "disappearing" and "appearing," stating it contradicts principles of special relativity.
  • There is a discussion about the nature of photons, with some asserting that photons are massless and their energy is related to frequency.
  • One participant introduces the concept of electron tunneling, explaining it as a quantum phenomenon where particles have a probability of being found outside their confining boundaries.
  • Another participant emphasizes that tunneling does not explain the "disappearing" and "appearing" notion presented by the original poster.
  • Concerns are raised about the original poster's personal theories and the need for grounding in established physics.
Participants generally disagree on the validity of the original hypothesis regarding "jumping" as a mode of movement for electrons and photons. While some provide critiques and alternative explanations, there is no consensus on the original poster's claims or the implications of tunneling in this context.
Participants express uncertainty about the original poster's claims and the relationship between energy, mass, and the behavior of photons. The discussion reveals a lack of clarity regarding the definitions and assumptions underlying the proposed ideas.
This discussion may be of interest to individuals exploring quantum mechanics, the behavior of light and particles, and the conceptual challenges in understanding particle movement at a fundamental level.
Alp_Oztek
I think that electrons can move by what I call jumping, that is disappearing in one place and instantly appearing somewhere else. The distance that can be jumped like this, in my opinion, has a relationship with the quantity energy/mass. If an electron can do it, a photon must also be able to do it, if the lower limit of energy/mass can be satisfied. Then, light would move by a series of consecutive jumps with very small time between two jumps. This would explain why light's speed cannot be exceeded, for a photon's energy/mass is infinite, since I have read somewhere that the mass of a photon is zero, and it would also explain how light can travel in vacuum.
I would really appreciate it if you could play devil's advocate and tell me of any mistakes or inconsistencies you find in this hypothesis and also your ideas. Thanks for your time and effort.
Science news on Phys.org
Electrons do not "disappear in one place" and "instantly appear somewhere else."
I heard that they do somewhat of an action of disapearing and apearing I'm just not sure exactly how it works...
From what I understand a photon is massless and has nothing but frequency. In order for it to travel a "c" it must have low energy, because as ironic as it is, when a particle traveling at high speeds, as light, the more energy, the slower it goes. In other words, energy slows it down. So I'm not 100% sure on what I'm saying, but I believe a photon's energy is it's frequency, emiting at different colors.
Here I found this at Wikipedia.com:
"Photons have zero invariant mass but a definite finite energy."
As Tide said,there's no such thing as "disappearing" from one place and "appearing" in another one.It would contradict the second postulate of special relativity which governs the "movement" of light.
1.A photon is massless.
2.It has only energy,taking \hbar=1,it's energy is the same with frequency,taking c=1,its energy is the same with relativistic mass.The speed of propagation (in vacuum) has nothing to do with its frequency.The energy/frequency/relativistic mass can be as large as one may want,the speed is still "c".
3.The citation from wikipedia si correct,generally educated people write articles there. :-p
Daniel.
Electron tunnelling:
http://www.cartage.org.lb/en/themes/Sciences/Chemistry/Inorganicchemistry/Informationbonding/Electrontunneling/ET03.gif
"A quantum particle can be described by a waveform which is the plot of a mathematical function related to the probability of finding the particle at a given location at any time. If the particle is confined to a box, it turns out that the wave does not fall to zero at the walls of the box, but has a finite probability of being found outside it. This means that a quantum particle is able to penetrate, or "tunnel through" its confining boundaries. This remarkable property is called the tunnel effect."
http://www.cartage.org.lb/en/themes/Sciences/Chemistry/Inorganicchemistry/Informationbonding/Electrontunneling/electrontunneling.htm
However, take note that for an infinite well, the wavefunction IS zero at the boundary and that there is zero probability of any extension into the forbidden region. This is typically the first exercise a student sees in a QM class.
Another thing to keep in mind about quantum tunneling is that there are two separate probability to consider that affects the ability of a particle to tunnel through: (i) the probability rate itself, and described by the tunneling matrix element, and (ii) the probability that the state it is tunneling to is empty. This is especially true for fermions which have occupancy restrictions. Thus, even if there is a large probability of tunneling for an electron, if the state it can tunnel through is occupied, then it will either need to gain/lose energy to tunnel to a different empty state (a lower probability) or not tunnel at all!
I must say that I don't get the reason why you are introducing an electron tunneling effect in this thread. The "disappearing" and "appearing" that were mentioned in this thread isn't due to any tunneling effect.
Zz.
Tunneling is a well know and understood phenomena. However, It is not how electrons or photons move. The original poster needs to be aware that his personal theories are not welcome here. If he wishes to learn how modern physics views the universe he needs to read more posts in these forums and post questions about what he reads. It would also be very helpfully to suppress preconceived notions which may not be based on sound physics.
  • · Replies 23 ·
  • · Replies 19 ·
