The Relativity Of Simultaneity.
The discussion centers on the concept of simultaneity in the context of special relativity, specifically examining the scenario of two lightning strikes observed from two different reference frames, S and S'. Participants explore whether events that are simultaneous in one frame can also be considered simultaneous in another frame, and how the definition of simultaneity applies across different observers' perspectives.
  • One participant argues that since the lightning strikes occur simultaneously at points A and B for observer S, they should also be simultaneous in the S' frame, suggesting that simultaneity should be determined by clocks in that frame.
  • Another participant counters that the lightning strikes do not occur simultaneously in the S' frame, emphasizing that the light pulses do not arrive at the midpoint O' at the same time.
  • A further response clarifies that the location O' is not midway between the light pulses when they arrive, indicating that the strikes were not simultaneous in the S' frame.
  • One participant references a section of a textbook to support the definition of simultaneity, asserting that the definition must hold true across frames.
  • There is a reiteration that the simultaneity of events is frame-dependent, and the clocks in S' are set accordingly to reflect this.
Participants express disagreement regarding the simultaneity of events in different frames. While some argue for the possibility of simultaneity in both frames, others maintain that the events cannot be simultaneous in the S' frame based on the behavior of light and the definition of simultaneity.
The discussion highlights the complexities of simultaneity in special relativity, including the dependence on the observer's frame of reference and the implications of light propagation. There are unresolved assumptions regarding the interpretation of simultaneity and the application of definitions across different frames.
siddharth5129
Say there are two observer S and S'. Let's assume that their frames coincide at the instant t=0 and that observer S' is moving to the right at a speed 'v' with respect to the observer S along the X axis. Two lightning strikes occurs at the points A and B in the S frame at t=0. The corresponding points in the S' frame are A' and B', which coincide with A and B at t=0. My textbook says that the two events are simultaneous for the observer S, but not for the observer S'. This is what I don't get. The events are simultaneous for the observer S because the light pulses from the two events hit the midpoint O at the same time. Now, in determining whether or not the event is simultaneous in the S' frame, shouldn't we analyze the scenario form the S' frame, in which case, the light pulses would arrive simultaneously at O', and the two lightning strikes would be simultaneous in the S' frame as well. Isn't it erroneous to analyze the scenario from the S frame and then claim that the two events are not simultaneous in the S' frame. Shouldn't simultaneity of events in a frame be determined by clocks in that frame. In this case, the events would be simultaneous for both observers.
You are assuming that the lightning strikes at A' and B' occur simultaneously according to the S' frame. But they don't.
Except that in the primed frame O' is not midway between the light pulses when they arrive at O'. Since the light arrives simultaneously at a location that is not midway between them then you know that they did not occur simultaneously.
It could be good to start with http://www.fourmilab.ch/etexts/einstein/specrel/www/ section 1, "Definition of simultaneity".
Assuming that you understand that part, I continue:
You know that in S the flashes arrive at the same point O (and not O') at the same time; this cannot be otherwise in S' (if this is not immediately clear, try to find a way how it can be any different!). From the fact that the flashes don't arrive at the same time at midpoint O', it is immediately clear that the strikes "were not simultaneous in S' " - according to the definition of simultaneity in S'. The clocks of S' are set accordingly.
  • · Replies 20 ·
  • · Replies 38 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 51 ·
  • · Replies 221 ·
19K
  • · Replies 16 ·
