New Reply
Audio amplifier using only 1 op-amp [single supply]
Share Thread
Feb20-12, 04:50 AM   #1
As the thread suggests, I am trying to amplify the signal from a microphone.
Now, I have a circuit which uses 2 op amps with dual supply.
That circuit works pretty well.
I have to make now, a amplifier using only one op amp, single supply.
The sound itself isn't of much importance, I just need the signal, it can be distorted(a little),
because I am not sending that signal to a speaker, but to a LED driver, in bar mode.
I attached a circuit.
Can this be done with only 1 op amp, and if it can, can somebody suggest me a circuit?
Thank you.
p.s. I am using elecrtet microphone.
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Feb20-12, 11:31 AM   #2
Engineering 2012
Recognitions:
Gold Membership Gold Member
my browser is giving trouble cant see your sketch
anybody else getting 502 errors on IE?
anyhow,
check LM386 it's a versatile little audio amplifier
Feb20-12, 12:02 PM   #3
Hmmm. I will buy it tomorrow. This may as well solve my problem!
It even works with single supply! Thank you mr. Jim!
Feb20-12, 12:38 PM   #4
Not sure I get your question.
Why not just use any op amp with a resistor in the feedback and a resistor in the input? Gain will be -RF/Ri if the + terminal is grounded. If the negative output is a problem.....put your input into the positive terminal.....ground the former input resistor....and the same feedback resistor. Gain will be (1+ RF/Ri)
If you need to filter out high end frequencies....put a capacitor in parallel with the feedback resitor. If you want to get rid of lower frequencies....put a resistor in series with the input resistor?
Break frequencies happen at 1/(2*pi*R*C)?
The basics of op amps right? Am I missing something......probably!!!
I'm more than sure the LM386 will work great....but wouldn't pretty much any op amp work as long as it has the required power you need?????
Feb20-12, 12:43 PM   #5
Quote by psparky View Post
Problem was mainly because, my microphone was driving the op amp into negative saturation.
So I had to raise the voltage on the +ive lead. That solved the problem. Or so I thought. Now I had problem with gain. I put a 100 000 ratio resistors, but op-amps frequency characteristics knocked in, and I was pretty much nowhere. Then I thought, why not use again 2 op amps with single supply. I tried that, with different resistor ratios, and I was almost there, but I couldn't get the gain needed. I wasn't amplifying all frequencies equally enough(I think that was the problem). I did work on this like half an hour(spent 4h working on other parts of this project), was really tired, I will try again tomorrow(this with 2 op amps)
So I will probably go with this IC mr. Jim suggested. That looks like a winner, and I don't have to bust my head with 2 op amps.
Feb20-12, 12:50 PM   #6
Wow....the LM86 costs a whopping 2 dollars! Not bad.
For fun....play with some capcitors in the feedback in paralell.....and some capacitors in series to see if you can cut off low and high frequencies outlined to what I said above.
If you get it to work....you just designed a basic "equalizer". Put in a variable resistor in the feedback and you now have a volume control.
Feb20-12, 01:04 PM   #7
Oh....I was just able to really zoom in on your drawing......you certainly did use to op amps as non inverting amps.....cool.
I guess having an op amp powerful enough is your only issue. Might wanna check the specs on the LM386 before you get it. Then again...for $2, no biggy.
Feb20-12, 01:04 PM   #8
Yes I am enjoying this very much. And here at my store, LM386 is a dollar :P
Will try that!
This project was something my teaching assistant gave me, you know, for fun. Problem is, I don't have oscilloscope at home, nor dual supply, so I am limited to my lab at university.
Feb20-12, 01:34 PM   #9
Engineering 2012
Recognitions:
LM324 is a great little single supply opamp but not much current drive and not real fast.
It'll run from a 9v battery or wall-wart .
I bought a tube of them, lifetime supply, for just a few bucks..
4 amps in a 14 pin DIP!
Feb20-12, 02:30 PM   #10
Quote by jim hardy View Post
anyhow,
It's been bad the last few days, I couldn't get in for a few hours two days ago and this is the first time I can get in today. Yes, 50x error.
New Reply
Similar discussions for: Audio amplifier using only 1 op-amp [single supply]
Thread Forum Replies
audio amplifier circuit Electrical Engineering 8
Why does a buffer is used in an audio amplifier? Electrical Engineering 13
Need help with a 12 watt Audio amplifier Electrical Engineering 13
Single Supply Summing Amplifier Electrical Engineering 12
single ended audio amplifier why need DC block Electrical Engineering 5
