Frictional force, velocity, and acceleration
The discussion revolves around a physics problem involving a log being pulled by a rope with a specific force, examining the concepts of frictional force, constant velocity, and acceleration. The participants explore the implications of the forces acting on the log and how they relate to motion.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the applied force and the frictional force when the log moves at constant velocity. There is confusion regarding the implications of constant velocity on acceleration and friction.
  • Some participants attempt to set up equations based on free body diagrams to analyze the forces acting on the log.
  • Questions arise about the correct interpretation of the forces involved and whether the calculations align with the physical scenario described.
There is ongoing exploration of the concepts of friction and net force, with some participants providing insights into the nature of forces when an object moves at constant velocity. Guidance has been offered regarding the interpretation of the forces and the necessity of understanding the conditions under which the log moves.
Participants note the assumptions made in the problem, such as the constancy of the frictional force and the conditions for acceleration. There is also mention of the need for clarity in setting up the problem and the potential for misunderstanding the relationship between forces and motion.
iJamJL
A rope is tied to a log of mass m = 99.9 kg. When you pull on the rope with a horizontal force of magnitude F = 688 N, the log moves at constant velocity.
a) Find f, the magnitude of the resistive (frictional) force acting on the log. You may assume the frictional force acting on the log is constant.
b) Find the magnitude of the horizontal force F needed to pull the log with an acceleration of magnitude a = 5.42 m/s2. Assume the resistive force is the same as in part a.
F = ma
I'm actually stuck on the fact that the problem says that when we pull with a force of 688N, the log moves at constant velocity. Wouldn't that mean that there is (a) no friction, and (b) acceleration = 0? Obviously I'm wrong, but that's how I'm interpreting it, and I sort of have a mind block that won't let me get around it.
Even if we solve for acceleration, F = ma
688N / 99.9 kg = 6.8869 m/s2
Would we have to find a frictional force that would make this acceleration 0 and the velocity constant?
Welcome to Physics Forums.
F = ma
Constant velocity does mean acceleration = 0, and hence the net force (∑F) is zero. You can't say that any particular force is zero, only that the vector sum of all forces acting on the log is zero.
Have you drawn a force (free body) diagram for yourself?
Thank you for the welcome and response.
I did draw a free body diagram, but I might be doing it wrong. I just have a mass of 99.9kg that is being pulled on by a force of 688N to the right (F1). As you said, the net force should be equal to 0, so what I have set up now is another force going to the left to show that it is a frictional force (Ff). Now I have this set up:
F1+Ff = m*a
688N+Ff = (99.9kg)*0 (because constant velocity means 0 acceleration)
(688N+Ff)/(99.9kg) = 0
Ff = -688
That doesn't seem quite right because if I am pulling on the log at 688N, and the frictional force is -688, then the log is receiving complete resistance and isn't moving. There's something wrong with my calculations, and I can't see it.
It's good that you are thinking about the implications of your results.
The fact that the two forces add to zero means that the acceleration, and not necessarily the velocity, is zero. What happens in reality is that a force greater than 688 N is applied at first to get the log moving, and then the applied force will be 688 N after it starts moving, in order to maintain a constant velocity.
So your calculation of the friction force (688 N in the opposite direction as the applied force, i.e. -688 N) is correct. :smile:
Thank you very much, Redbelly98! This part one of a two-part question, and I needed that part solved correctly before I could answer the other. I got them both correct, so I'm glad.
I do admit that I have two more questions which I'm stuck on, and I'm hoping it's alright to post those questions here instead of making a new thread. Please let me know if I should make a new one.
Here they are:
Mass m sits on a frictionless, horizontal table. Assume:
- All vertical forces acting on m (such as gravity and the normal force) sum to zero.
- All applied forces act parallel to the table
When a force of magnitude F is applied to mass m, it accelerate at magnitude a = 4.49 m/s2.
NOTE: The axes lie along the table.
Suppose force F1 has magnitude 2F and points at 45 degrees to the x-axis. If forces F1 and F2, with a magnitude F, act on mass m at the same time, what will the magnitude of its acceleration be now?
Components
I attempted to solve this by drawing a diagram, and F1 is pointing out at 45 degrees relative to the x-axis. I found its components, with the x-direction vector being 8.98cos(45) = 6.3498. F2 is already in that direction as well, so I just added the two vectors to get a sum of 10.8398. When I entered this answer as 10.84 into Webassign (online homework - I don't know who is familiar with it), it said that the answer is incorrect. Is it that I didn't put enough digits, or did I solve the problem incorrectly?
A red box and a blue box sit on a horizontal, frictionless surface. When horizontal force F is applied to the red box, its acceleration has magnitude a = 5.09 m/s2.
a) If force F is applied to the blue box, its acceleration has magnitude a = 1.24 m/s2. Find mred/mblue, the ratio of the mass of the red box to the blue box.
b) Now, the two boxes are glued together. If horizontal force F is now applied to the combination, find a-combo, the magnitude of the acceleration of the combination of boxes.
F = ma
I already correctly answered question a, which came to be a ratio of .2436. The second part, however, always confuses me because there has to be some sort of manipulation. Intuitively, when we put together the two boxes, we are combining their masses, making the total acceleration even smaller than what they were individually. This is true because we are applying the same amount of force to both of the objects. To get the numerical answer for the combined acceleration, I have no idea. I already know that adding the two accelerations together (two vectors in the same direction) and then multiplying it by the ratio (6.33 m/s^2 * .2436) gives me an incorrect answer, so that is probably a poor approach. I'm just stuck, like the rest of the problems I've had. lol it's quite frustrating.
Hi again,
Please make new threads for each new question.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 21 ·
