Finding Charge Conjugation Eigenvalues
The discussion revolves around the concept of charge conjugation in particle physics, specifically focusing on how to determine the charge conjugation eigenvalues for particles such as the \(\rho^0\) meson and the \(e^+e^-\) system. The scope includes theoretical aspects of particle interactions and properties related to discrete symmetries.
  • One participant notes that the charge conjugation eigenvalue for the \(\rho^0\) meson is stated as -1 based on its decay into an \(e^+e^-\) pair, questioning how the eigenvalue for the \(e^+e^-\) system is determined.
  • Another participant explains that the eigenvalues of charge conjugation for fermion-antifermion states depend on the spin and orbital angular momentum, leading to the conclusion that \(C=(-1)^{L+S}\) for such states.
  • A participant draws a parallel between charge conjugation and parity, inquiring whether the reasoning for returning to the original state is similar for both symmetries.
  • Another participant clarifies that while both charge conjugation and parity are discrete symmetries, they operate differently, with specific factors contributing to their respective eigenvalues.
Participants express differing views on the relationship between charge conjugation and parity, indicating that while there is some agreement on the discrete nature of both symmetries, the specifics of their operations and implications remain a point of discussion.
The discussion includes assumptions about the definitions of charge conjugation and parity, as well as the specific properties of the particles involved, which may not be universally agreed upon or fully resolved.
v0id19
I've just recently been introduced to charge conjugation while reading the introductory particle physics texts by Griffiths and Perkins, and neither one really seem to explain how you go about finding the values for C.
For example, if I wanted to find the value for the [itex]\rho^0[/itex] meson (which I believe should be -1), the only real example in Perkins simply says [itex]C_{\rho} = -1[/itex] since [itex]\rho^0 \rightarrow e^+e^-[/itex], from which I assume that we (somehow) know that the [itex]e^+e^-[/itex] system has C=-1 and by charge conjugation conservation so does the [itex]\rho^0[/itex]. But how does actually go about figuring out the [itex]C_{e^+e^-}[/itex]?
Both the [itex]\rho^{0}[/itex] and the [itex]e^{+}e^{-}[/itex] system are fermion-antifermion states. For these states, the eigenvalues of C depend on the spin and orbital angular momentum of the system. The reason is that the C operator transforms a particle to its antiparticle, but doesn't change the spin or momentum. Therefore, in order to return to the initial state one needs to exchange the momenta in the spatial wave function which gives a factor [itex](-1)^{L}[/itex] and the spin in the spin wave function which gives a factor [itex](-1)^{S+1}[/itex] (when adding two spin 1/2, s=0 antisymmetric, s=1 symmetric). in addition there is another (-1) factor due the exchange of two fermions. therefore, in total you get that C=[itex](-1)^{L+S}[/itex]. In the quark model [itex]\rho^{0}[/itex] is a quark anti-quark bound state with S=1 and L=0 (J=1), and therefore C=-1. Meaning that a [itex]e^{+}e^{-}[/itex] state that it would decay to must have an odd L+S.
Ah I see, that makes sense. So charge conjugation in fermions is similar to parity then (when you say you need to exchange angular momentum/spin to return to the original state), or is this not a good way to think about it?
They are both discrete symmetries, but they act differently.
In the case of parity, the spin doesn't change and the particle identity doesn't change, it is only the momentum which changes sign. In order to return to the initial state one has to change the momenta sign in the orbital wave function, which gives a factor [itex](-1)^{L}[/itex]. In addition, the intrinsic parities of a fermion and its antiparticle are of opposite sign, therefore the a fermion-antifermion pair has odd intrinsic parity. This give another factor (-1),
giving a value of P=[itex](-1)^{L+1}[/itex]. For example the pion, which has L=0, has P=-1 (pseudoscalar).
  • · Replies 0 ·
