Determining Coefficients of Friction
The discussion revolves around determining coefficients of friction using an apparatus where a block slides down an incline and compresses a spring. The participants are tasked with deriving expressions for the coefficient of static friction, the loss in mechanical energy, and the coefficient of kinetic friction based on the setup described.
  • Participants discuss the relationship between frictional force and normal force, with some emphasizing the importance of free body diagrams. There are attempts to clarify the conditions under which static and kinetic friction are defined, particularly when the block begins to slide.
Some guidance has been offered regarding the equations of motion and the forces acting on the block. Participants are exploring how to apply these concepts to derive the required expressions, but there is a lack of consensus on the next steps, with some expressing confusion about the problem setup.
Participants are working under the constraints of deriving expressions based on the given quantities without providing complete solutions. There is an emphasis on understanding the definitions and conditions of static and kinetic friction.
Elphaba
An apparatus to determine coefficients of friction is shown above. The box is slowly rotated counterclockwise. When the box makes an angle (Theta) with the horizontal, the block of mass m just starts to slide, and at this instant the box is stopped from rotating. Thus at angle(Theta), the block slides a distance d, hits the spring force constant k, and compresses the spring a distance x before coming to rest. In terms of the given quantities, derive and expression for each of the following.
(a) u(s). The coefficient of static friction
(b) (change in)E, the loss in total mechanical energy of the block-spring system from the start of the block down the incline to the moment at which it comes to rest on the compressed spring.
(c) u(k). The coefficient of kinetic friction
Can you show some of your work? Where are you getting stuck?
For part a, remember that when the block starts to move, the maximum static frictional force is just barely overcome... so acceleration can be taken to be zero.
all i know is that F=uN
Yes, but just remember
[tex]f_{static max}=u_{static}N[/tex]
[tex]f_{kinetic}=u_{kinetic}N[/tex]
Reason I've put in the static max subscript is because, when you try to move the block, the frictional force will increase to prevent the block from moving, until a max value when it starts to move. It's this max value that's used for the equation above.
If you can find f and N when it just starts moving then you can find [tex]u_{static}[/tex]. Draw a free body diagram of the mass m. Draw all the forces. Let's take x to be parallel to the plane, and y to be perpendicular to the plane. Write out these equations:
[tex]\Sigma F_{x}=ma_{x}[/tex]
[tex]\Sigma F_{y}=ma_{y}[/tex]
Just as the block starts moving, the acceleration along the plane is 0. And since the block isn't moving perpendicular to the plane, the acceleration perpendicular to the plane is 0.
So for part a the equations are:
[tex]\Sigma F_{x}=0[/tex]
[tex]\Sigma F_{y}=0[/tex]
So substitute in all the forces, get and then get f and N. Then you have [tex]u_{static}=f/N[/tex]
um... what?
  • · Replies 16 ·
9K
  • · Replies 33 ·
