Magnetic Field at center of circle on rectangular circuit
The discussion focuses on calculating the magnetic field at the center of a circular section within a rectangular circuit consisting of 7 wire sections. The rectangle measures 9 cm by 5 cm, with a circle of diameter 3 cm intersecting one of the 9 cm sides. The user seeks guidance on whether to use the current from the rectangular part of the circuit or the circular section when applying the formula for the magnetic field of a circular loop. The importance of symmetry in determining the magnetic field is emphasized.
  • Understanding of Ampère's Law
  • Knowledge of magnetic fields generated by current-carrying conductors
  • Familiarity with the concept of symmetry in physics
  • Basic circuit analysis, including resistance and current calculations
  • Study the application of Ampère's Law in complex circuits
  • Learn about the Biot-Savart Law for calculating magnetic fields
  • Explore the effects of resistance in parallel and series circuits
  • Investigate the principles of magnetic field symmetry in circular loops
Students in physics or electrical engineering, educators teaching circuit theory, and anyone interested in understanding magnetic fields in complex circuit configurations.
soccerscholar
A circuit consists of 7 sections of wire. The figure looks like a rectangle of length 9cm and width 5cm with a circle of diameter 3 cm cutting right through the middle of one of the 9cm sides so that the two sides of the circle are in parallel. Each of the sections of wire also has a resistance. I am supposed to find the magnetic field at the center of the circle using symmetry.
So I figured out the current based on the givens, but how do I find the magnetic field at the center of the circle using this? Which current would I use in the equation for magnetic field of a circular loop (Bcircular loop- see above), would I use the current of the rectangle part of the circuit, or one of the currents in the circle? How do I factor in the effect of the rectangle when I calculate the magnetic field at the center of the circle? Thanks for any help, I just need guidance and hopefully I'll be able to figure it out from there.
It be better if you substitute your so lengthy question with a small figure and a reasonable question. Point out the exact matter of doubt instead of writing this and that. It makes more sense then.
