New Reply
Use the definition of E[g(Y)] to derive E[Y^2]
Share Thread Thread Tools
Feb21-12, 09:24 AM   #1
Let Y ~ Bi(m,q).
Use the definition of E[g(Y)] to derive E[Y^2].
Hint: Write Y^2 as Y(Y-1) + Y. You do not have to re-derive E[Y].
Not sure where to start with this; my initial reaction was to use the moment generating function?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb21-12, 10:45 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Please post such questions in the homework forum. I moved it for you.
Feb21-12, 10:49 AM   #3
Recognitions:
Homework Helper Homework Help
Quote by mathmajor23 View Post
Let Y ~ Bi(m,q).
Try it and see!
RGV
Feb21-12, 01:46 PM   #4
Recognitions:
But the directions say to use the definition of the expectation of a function of a random variable.
Feb21-12, 02:53 PM   #5
Recognitions:
Quote by Stephen Tashi View Post
A moment-generating function IS the expectation of a function of the RV; it just happens to be a particularly useful function.
RGV
Feb21-12, 07:29 PM   #6
Recognitions:
Quote by Ray Vickson View Post
RGV
Yes, it "is", in the same sense that the derivative "is" a limit. The definition of a moment generating function is an example of an expectation of a function of a random variable; it isn't logically equivalent to the definition of the expectation of a function of a random variable.
The meaning of the direction to "use the definition of E(g(y))" would be clearer if mathmajor23 explained how "E(g(y))" has been used in his course materials.
Feb21-12, 10:12 PM   #7
By definition, E[g(Y)] = the summation over all values of y of [g(y)p(y)]
Feb22-12, 02:14 AM   #8
Recognitions:
I speculate that the problem wants you to show your virtuosity with sums and binomial coefficients. (That's my attempt to mind-read what its author wants. If this problem is from the chapter on moment generating functions, it might want you to use them or it might want you do things "the hard way" so you'll appreciate moment generating functions!)
If we begin from the definition:
[itex] E(Y^2) = \sum_{k = 0}^m \ k^2 \ \binom{m}{k} q^k (1-q)^{m-k} [/itex]
and use the hint:
[itex] = \sum_{k=0}^m \ (k(k-1) + k) \ \binom{m}{k} q^k (1-q)^{m-k} [/itex]
[itex] = \sum_{k=0}^m \ k(k-1) \binom{m}{k} q^k (1-q)^{m-k} + \sum_{k=0}^m \ k \binom{m}{k} q^k (1-q)^{m-k} [/itex]
[itex] = \sum_{k=0}^m \ k(k-1) \ \frac{m!}{(m-k)! k!} q^k (1-q)^{m-k} + mq [/itex]
Does canceling the factors of [itex] k [/itex] let us rewrite the factors [itex] k(k-1) \binom{m}{k} q^k (1-q)^{m-k} [/itex] as [itex] q (1-q) m(k-1) \binom{m-1}{k-1} q^{k-1} (1-q)^{m-1-k}[/itex] ?
If, so the summation begins to look like a linear expression in the expectation of a binomial with parmeters [itex] m-1, q [/itex]. (Edit, This morning, I think that we should only factor out one of the factors [itex] q [/itex] and [itex](1-q) [/itex] to get a Bi[itex](m-1,q) [/itex].) It probably won't be that simple since you can't "cancel" out [itex] k [/itex] when [itex] k = 0 [/itex], but since the term is 0 you can leave it out of the summation. We'll have to pay attention to what the indexes of summation are. We might get an expression that involves the mean of bi(m-1,q) minus a few terms.
I began looking at this problem before it got moved to the homework section. I suppose now there's an excuse to leave it to you to see if that idea works.
Feb22-12, 11:22 AM   #9
You're right! My professor "loves" MGF and says she will make us appreciate them, and this is like the third proof we have to do with these nasty summations. I follow you all the way up to the point where you try canceling the factors of k, that's where I am getting confused. I will try rewriting the factors as you recommend and see where I go from there.
Feb22-12, 12:30 PM   #10
Recognitions:
What methods are you permitted to use? If I were not allowed to use an MGF I would, instead, assume a form like EN^2 = a*n^2 + b*n + c, then find a, b, c by looking at explicit values of EN^2 for small values of n, such as n = 1, 2, 3. Then I would try to _prove_ correctness of the result, by induction, for example. As regards induction: if we let b[n,k] = C(n,k)*p^k (1-p)^(n-k), then we have k*b[n,k] = n*p* b[n-1,k-1], etc.
RGV
Feb22-12, 10:32 PM   #11
My professor wants us to use just definitions and summations.
As to the last step of the ∑mk=0 k(k−1) m!(m−k)!k!qk(1−q)m−k+mq , the next thing to do is to cancel out the k's
Edit: I can't seem to get the summation symbol to agree with me on here :p
Feb22-12, 10:40 PM   #12
Recognitions:
What does it mean to use "just summations"? Are you not allowed to use modern summation tools? Are you not allowed to recognize that k*b[n,k] is the same as n*p*b[n-1,k-1]? If you are not allowed to use *anything*, what on Earth are you left with?
RGV
Feb24-12, 11:18 PM   #13
You can derive E(Y^2) easily:
let f(x) = ƩC(m,x)*q^x * (1-q)^(m-x)
E(X^2) = ƩC(m,x)*x^2 *q^x * (1-q)^(m-x)
Observe that this is equivalent to ƩC(m-1,x-1)*(m/x)*q^x*(1-q)^(m-x)*x^2
This becomes:
ƩC(m-1,x-1)*(m)*q^x*(1-q)^(m-x)*x
Let y = x-1
x = y+1
ƩC(m-1,y)*m*q^(y+1)*(1-q)^(m-1-y)*(y+1)
This equals
ƩC(m-1,y)*m*q*q^(y)*(1-q)^(m-1-y)*(y+1)
This equals mq*ƩC(m-1,y)*q^(y)*(1-q)^(m-1-y)*(y+1)
Expand via factor (y+1)
mq*ƩC(m-1,y)*q^(y)*(1-q)^(m-1-y)*(y) + mq*ƩC(m-1,y)*q^(y)*(1-q)^(m-1-y)*(1)
The term on the right is simply mq, because the sum itself is equal to 1
The term on the left can be solved easily:
mq*ƩC(m-1,y)*q^(y)*(1-q)^(m-1-y)*(y) becomes..
mq*ƩC(m-2,y-1)*((m-1)/y)*q^(y)*(1-q)^(m-1-y)*(y)
=mq*ƩC(m-2,y-1)*(m-1)*q^(y)*(1-q)^(m-1-y)
=(m-1)*mq*ƩC(m-2,y-1)*q^(y)*(1-q)^(m-1-y)
Let z = y-1
z+1=y
(m-1)*mq*ƩC(m-2,z)*q^(z+1)*(1-q)^(m-2-z)
=(m-1)*mq^2*ƩC(m-2,z)*q^(z)*(1-q)^(m-2-z)
= (m-1)*mq^2
So we have..
ƩC(m,x)*x^2 *q^x * (1-q)^(m-x) = (m-1)*mq^2 + mq
Feb25-12, 09:36 AM   #14
Recognitions:
Quote by Applejacks01 View Post
This becomes:
Let y = x-1
x = y+1
This equals
Let z = y-1
z+1=y
= (m-1)*mq^2
So we have..
That is more-or-less what I suggested to him a few postings back, but he seemed to think he was not allowed to use such results.
RGV
New Reply
Thread Tools
Similar Threads for: Use the definition of E[g(Y)] to derive E[Y^2]
Thread Forum Replies
how to derive tan(2x) using the definition of the derivative ? Calculus & Beyond Homework 4
How do you derive E2= (pc)2 + (mc2)2 Special & General Relativity 12
"Definition" of Curl. Can anyone derive the gradient operator? General Math 5
Derive Ohm's law? General Physics 16
In QM: How to derive <x|f> from f_n(x)? Advanced Physics Homework 4
