| New Reply |
What can I use to make clear dish soap thicker? |
Share Thread | Thread Tools |
| Feb21-12, 12:47 PM | #1 |
Hello this is my first post to this forum though I've lurked before.
I want to paint with something 100% clear and quite viscous. I added food coloring to transparent dish soap and that is so far the best solution to a clear paint body, but I want to make it thicker. I found a list of common ingredients in dish soap here, and I may be mistaken but I figured if I knew which ingredient is a thickening agent that doesn't increase opacity, I could simply add more of it to the dish soap and get a thicker gel. From what I could find only the PPG (propylene glycol) and alkyl dimethyl amine oxide are thickeners. So I would like to know if any of you know the properties of these chemicals. How transparent are they and how viscous are they? And is it possible to buy in retail quantity? I found PPG on amazon but I'm not sure if it's the right thickness. I found this DOW link and I'd like to get my hands on their thickest product but of course I can't buy in bulk from DOW. I've looked into other thickeners that are clear, stearic acid seems like my best bet and if anyone's worked with it before I'm wondering if I would have to melt it in with soap and generally how it performs generally. |
| Feb21-12, 11:27 PM | #2 |
You're painting with soap? Anyway, the dimethylamine oxide is one of the surfactants... not a thickener. The PPG/PEI/PEG copolymers are functional in surfactants formulations. They are wetting agents, emulsifiers and coupling agents. The real thickener wasn't given in that answer.
For thickeners, go here. |
| Feb22-12, 12:51 PM | #3 |
Yes I am. Thanks my bad.
I just spent about 3 hours reading from that link. The Carbopol products look perfect. Would you know where to get their products at retail? The only retailer I could find is from here, I think I'll try them but they only have one carbopol formula, I want to try others mainly the ultrez 21 too. The only other possibility involves making up a business name and asking the supplier for a sample (bad idea?) |
| Feb23-12, 02:41 AM | #4 |
What can I use to make clear dish soap thicker?I really like the Carbopol type thickening. It makes processing amazingly easy provided there aren't any multivalent metals in the formulation. Of course as a chemist I can get samples fairly easily. YMMV. |
| Feb23-12, 12:20 PM | #5 |
Yeah okay. I still might get Carbopol from that one supplier I found if they work out but now I will definitely get some gelatin and gum arabic the next time I'm out. Thank you very much.
| Feb23-12, 01:07 PM | #6 |
Pectin is cheap and it is used for thickening all kinds of foods. Easy experiment.
| New Reply |
| Tags |
| dye, paint, soap, transparency, viscosity |
| Thread Tools | |
Similar Threads for: What can I use to make clear dish soap thicker?
| How to calculate the RPMs needed to make a spincast lquid parabolic dish? | General Physics | 3 | ||
| how to make clear ice.clear ice | General Physics | 17 | ||
| reaction of dish soap and bleach | Chemistry | 3 | ||
| Could i make this clear | Special & General Relativity | 12 | ||
| Does dish soap emulsify lipids in the cell membrane? | Biology | 1 | ||
