Graviton Quantization: Energy Needs of Particle Accelerator
  • Context: Graduate
  • Thread starter Thread starter serp777
    Quantization
The discussion revolves around the theoretical energy requirements for quantizing a graviton from a gravity field in the context of particle accelerators. It explores the relationship between energy scales, graviton production rates, and the implications of gravitational interactions at high energies.
  • One participant questions the understanding of the physics behind the energy requirements for graviton quantization.
  • Another participant suggests that the energy required is likely around the Planck scale (10^19 GeV).
  • A participant explains that the high energy requirement is due to the natural energy scale EPl and discusses the implications of a different quantum gravity scale.
  • There is a comparison made between the energy needed to create photons and gravitons, noting that while both require energy ħω, the production rates differ significantly due to the mechanisms involved.
  • One participant highlights that the Planck mass is relevant as it marks the energy at which gravitational interactions become comparable to other fundamental forces, but notes that spacetime may become unstable at such energies.
  • A later reply proposes that placing a particle accelerator near a dense object like a neutron star or black hole could enhance graviton detection due to increased mass quadrupole moments, suggesting a potential equilibrium near an event horizon for graviton quantization.
Participants express differing views on the energy scales involved and the mechanisms for graviton production, indicating that multiple competing perspectives remain without a consensus on the energy requirements or the feasibility of graviton detection.
The discussion includes assumptions about the nature of gravitational interactions and the production mechanisms for gravitons, which may not be fully resolved. The implications of energy scales and the stability of spacetime at high energies are also noted as areas of uncertainty.
serp777
Theoretically, how much energy in particle accelerator would be required to quantize a graviton from a gravity field?
I doubt if anyone knows the physics behind your question.
Probably somewhere around the Planck scale (10^19 GeV)
Any reason why the graviton would require so much more energy to become quantized?
This is the natural energy scale EPl; a theory of quantum gravity at a different scale EQG = xEPl with x << 1 would have to explain the smallness of x.
Q. How much energy does it take to create a photon?
A. ħω, where ω is the frequency of the photon.
Q. How much energy does it take to create a graviton?
A. Exactly the same, ħω.
Q. Well then, how come particle colliders create scads of photons but no gravitons?
A. It's not the energy that's the problem, it's the production rate. Photons are produced (primarily) by time-dependent electric dipoles. Gravitons are mainly produced by time-varying mass quadrupoles. You can crash two protons together and calculate their mass quadrupole moment as they collide, and then multiply that by the gravitational constant G to get the production rate. It's ridiculously small.
Q. What does the Planck mass have to do with it, if anything?
A. The Planck mass is the energy at which (presumably) gravitational interactions become comparable to the strong and weak interactions. So yes, you'd need a collider with that energy if you wanted to make the production rates comparable. But spacetime literally goes to pieces at that energy. If you really want to make gravitons, run at a much lower energy and be prepared to wait.
If the production rate of a graviton is determined by the mass quadrupole * G, then wouldn't the graviton be much more likely to be detected if you placed a particle accelerator very close to a dense object, such as a neutron star or a black hole? (Since the value of the quadrupole function becomes larger as mass, and therefore gravitational attraction, increases). My bet is that there is an equilibrium near an event horizon, where gravitons are likely to be quantized.
19K
Graduate Gravitons
  • · Replies 18 ·
  • · Replies 24 ·
