Function works on Windows but not Linux
The discussion revolves around a technical issue regarding the execution of a function, 'largestcomponent.m', which works on Windows but fails on a Linux system. Participants explore potential reasons for the discrepancy, focusing on path settings and input argument types.
  • One participant reports that the function runs successfully on Windows but not on Linux, receiving an error message related to undefined function or method.
  • Another participant suggests ensuring that the directory containing the function is included in the path settings.
  • A different participant encourages experimentation, proposing to test with a trivial function to verify if the file is being accessed correctly.
  • The original poster later confirms that the issue was indeed related to the path settings, despite having checked them previously.
Participants generally agree that path issues may be the cause of the problem, but there are differing suggestions on how to troubleshoot the issue effectively.
Limitations include the lack of detailed information on the specific error message and the exact nature of the input arguments being used.
Old Guy
I downloaded largestcomponent.m today and it runs fine on my PC (Win 7 Enterprise SP 1) but when I try it on my Linux machine (Ubuntu 10.04 LTS) I get this message:
? Undefined function or method 'largestcomponent' for input arguments of type 'double'.
Even if I put the function file in the same directory as the input it doesn't work on the Linux machine. Any suggestions?
make sure your 'set path' included the directory it's in.
the only other thing I can think of is you are accidentally handing a double to it when it should be something else.
get creative, don't be afraid to try stuff...nothing is going to happen, it is just a computer program...so, put your detective hat and try stuff.
to start, I would put a trivial function with no arguments...just to see if you are actually reaching such file, like mentioned before (path issues?)
Thanks to you both. Ultimately it was a path issue, although I thought I had checked that thoroughly before I posted.
  • · Replies 24 ·
  • · Replies 45 ·
