Thread Closed
Could a saint please guide me work through my research on AFFINE SETS AND MAPPINGS
Share Thread Thread Tools
Feb26-12, 07:11 AM   #1
This research project is to help me (I'm an undergraduate) get my head around this topic. It is concerned with affine subsets of a vector space and the mappings between them. As an
application, the construction of certain fractal sets in the plane is considered. It would be considered pretty basic to a seasoned maths student.
I am wanting to learn this so I will be sticking around. I will not just leave. I want to commit to this. Thanks
There are two parts: A and B
If someone is willing to help, I will post each topic AFTER I have fully understood the previous topic. This way it will run in a logical order.
PART A:
Throughout Part A, V will be a real vector space and, for a non-empty subset S of V and
a ε V , the set {x+a: x ε S} will be denoted by S + a
TOPIC 1: Definition of Affine Subset:
An affine subset of V is a non-empty subset M of V with the property that λx+(1-λ)y ε M whenever x,y ε M and λ ε ℝ
To illustrate this concept, show that:
M = { x = (x1,...x4) ε ℝ4 : 2x1-x2+x3 = 1 and x1+4x3-2x4 = 3}
is an affine subset of ℝ4.
I'm not so sure where to start. Opinions welcome
Regards
Tam
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb26-12, 08:05 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Take x and y in M. You must show that [itex]\lambda x+ (1-\lambda) y\in M[/itex]. Call this number z for convenience.
To show that z is in M, you need to show that
[tex]2z_1-z_2+z_3=1~\text{and}~z_1+4z_2-2z_4=3[/tex]
You know that [itex]z_i=\lambda x_i + (1-\lambda) y_i[/itex] so substitute that in.
Feb27-12, 09:50 AM   #3
Quote by micromass View Post
Okay great.
So subbing in z we get:
LHS:
2(λx1+(1-λ)y1) - (λx2+(1-λ)y2) + (λx3+(1-λ)y3)
Now taking:
λ(2x1-x2+x3) We know that the bold part = 1
(1-λ)(2y1-y2+y3) We again know that the bold part = 1
so we have λ + (1-λ) = 1 = RHS
AND NOW DO THE SAME WITH THE SECOND PART X1+4X3-2X4 = 3... IVE DONE THAT IN MY OWN TIME.
So I think I've grasped that. I will look at the next topic and report back when Ive had a go. Thanks Micro
Feb27-12, 10:23 AM   #4
Now Topic A2
Let M be an affine subset of V.
QUESTION: Prove that M+a is affine for every a ε V and that, if 0 ε M, then M is a subspace
So my attempt:
Proof: x,y is in M+a
take: x = m1+a and y = m2+a for some m1,m2M
Therefore, λ(m1+a) + (1-λ)(m2+a)
Now rearranging gives:
(i) λm1 + (1-λ)m2 which must be in M by definition.
(ii) λa + (1-λ)a
=a(λ+1-λ)
=a
Hence, λm1 + (1-λ)m2 + a is in M+a. So M+a is affine.
I'm unsure of what to do with the zero part of the question?
Feb27-12, 11:39 AM   #5
Recognitions:
So assume that 0 is in M. You must prove that it is a subspace. So you must check the axioms of being a subspace.
Feb28-12, 09:13 AM   #6
OKay, using the definition: Let M be a subspace of vecotr space V. Then M is a subspace of V IFF
i) 0 ε M
ii) x+y ε M for all x,y ε M
iii) λx ε M for all x ε M
(i) holds since we are assuming 0 ε M
(ii) holds since we showed this in the last part of the question
(iii) holds since in the last part of the question λx ε M
Is this enough? I'm unsure of (iii)
Regards
Tam
Feb28-12, 09:17 AM   #7
Recognitions:
Quote by tamintl View Post
i) 0 ε M
Regards
Tam
Could you explain (ii) and (iii)?? You have to use the assumption that 0 is in M for all of these questions.
Begin by showing (iii). Apply the definition of M affine on x and 0.
Feb28-12, 09:33 AM   #8
Okay, on x,
λx + (1-λ)x will be in M by definition
on 0,
λ(0) + (1-λ)(0) = 0 which is in M since we are assuming 0 ε M
Have I understood you?
Feb28-12, 09:37 AM   #9
Recognitions:
No. You have to show that for any x and for any λ, that λx is in M.
You know that M is affine, so you know that for any x and for any y, we have that λx+(1-λ)y is in M.
Now choose a special value of y.
Feb29-12, 09:36 AM   #10
Oh okay. If we take y=0 (using the condition 0€M)
Then we get (lambda)x + (1-lambda)(0) which is just (lambda)x
So we know for any x and lambda that it will be in M. So that is iii done.
What about ii
Ps: I'm on my phone so sorry for weak notation.
Thanks micro
Feb29-12, 09:38 AM   #11
Recognitions:
For (ii), you need to prove that if x and y are in M, then x+y is in M.
You know that for each r and s in M that
[tex]\lambda r+(1-\lambda)s\in M[/tex]
Now choose the right r and s such that we can conclude that x+y is in M. Use (iii).
Feb29-12, 09:53 AM   #12
Take r=x and s=0 so since we know (lambda)x is in M, x+0 is in M.
Or could we use the M+a proof?
Mar1-12, 04:39 AM   #13
bump?
Mar1-12, 04:43 AM   #14
Recognitions:
is it permissible to set λ = 1/2?
Mar1-12, 07:25 AM   #15
Quote by Deveno View Post
Yes, I think...
Edit: taking λ = 1/2
f(x+y) = f(1/2(2x)) + f(1/2(2y))
= 1/2 [ f(2x) + f(2y) ]
taking 2 out gives:
= f(x) + f(y)
Hence closed under addition
Is that sufficient?
Thanks
Mar2-12, 02:56 PM   #16
Recognitions:
Yes, I think...
taking 2 out gives:
= f(x) + f(y)
Is that sufficient?
Thanks
where does "f" come from?
my reasoning goes like this: 1/2 and 1/2 sum to 1, so (1/2)x + (1/2)y is an affine combination, that is: (x+y)/2 is in M.
now, use part (iii) to conclude that.....
Mar4-12, 08:54 AM   #17
Yeah forget about the 'f's.. yeah that makes sense.
Deveno, if I sent you the question sheet it may be easier for both you and I to understand. Of course, only if you are happy to help. Would that be okay? The reason I ask is that it is hard for me to get my points across since I don't know latex.
Regards
Thread Closed
Thread Tools
Similar Threads for: Could a saint please guide me work through my research on AFFINE SETS AND MAPPINGS
Thread Forum Replies
Mappings on partitive sets Differential Geometry 2
Group Theory Sets and Mappings Calculus & Beyond Homework 5
Why the proof of Heine-Borel theorem doesn't work for open sets. Calculus 3
