Coordinate Geometry: Solving a Question for 0P
  • Thread starter Thread starter Mo
    Geometry
The discussion focuses on solving a coordinate geometry problem involving a line through the point (2,3) at a 45-degree angle to the x-axis, intersecting the line x=6 at point P. The correct coordinates for point P are (6,7), not (6,12) as initially calculated. The distance from the origin to point P is determined using the distance formula, yielding a result of √(6² + 7²). Additionally, the equation of the line through P that is perpendicular to OP is derived from the slope of OP, which is 1, resulting in the equation y = x + 1.
  • Understanding of coordinate geometry concepts
  • Familiarity with slope and line equations
  • Knowledge of the distance formula in geometry
  • Ability to solve linear equations
  • Study the distance formula in coordinate geometry
  • Learn how to derive equations of lines from given points and slopes
  • Explore the concept of perpendicular lines and their slopes
  • Practice solving problems involving angles and slopes in coordinate systems
Students studying coordinate geometry, educators teaching geometry concepts, and anyone looking to improve their problem-solving skills in mathematics.
Mo
Another question here .. i attempted it but did not get the correct answer.I will state the question and the steps i took as well.
QUESTION:
"A line is drawn through the point (2,3) making an angle of 45 degrees with the positive direction of the x-axis, and it meets the line x=6 at P.Find the distance of P from the origin 0, and the equation of the line through P perpendicular to 0P"
Steps i took:
1)Since i have to find out the distance of 0P i need to have the Y value of the point P. I assumed the X value is 6 (well, they tell you that anyway)
2)To work out the Y value of P i figured that it needs to be worked out by using the equation of the line (2,3). (ie substitue in an X value to the equation of the line (2,3) to get the Y value of point P)
3)However, to work out the equation of the line (2,3), i also have to know the gradient.I worked this out to be 3/2 (Is this right?)
4)Next i found the equation of the line (2,3) and then i substitued in the X value of P (6) .I found the Y-value to be 12. (Is this right?)
5)Now i work out the length of the line (0,0)(6,12) , and it comes out to be: squareroot of 180
Hmm .. I am sure all of this is not needed .. i bet (hope/wish) someone will come out with a one line asnwer!
Anyway, any help whatsoever is appreciated
Regards,
Mo
OK.
OK.
The slope of the line is 1 (it's at a 45 degree angle), so the equation of the line is y = x + 1. (Perhaps you mistakenly thought that the line goes through the origin? That's how you might have gotten slope = 3/2.)
No, because you have the wrong equation for the line.
Using the correct equation, the point P is (6,7). So find the distance to the origin.
To find the equation of the line through P that is perpendicular to the line OP, do this: First find the slope of OP; then find the slope of the perpendicular line. Then, using the point P, find the equation for that line.
Yes. Thats where i fell down! .All of the questions i have had so far was involving the line going through the origin. But now i see why they said 45 degrees as well.The answer i now get is correct according to the answer sheet.
Thanks for your help again.
Regards,
Mo
  • · Replies 23 ·
  • · Replies 64 ·
  • · Replies 105 ·
  • · Replies 17 ·
