| New Reply |
slit pattern, vertical or horizontal? |
Share Thread |
| Feb27-12, 11:42 AM | #1 |
This has already been asked:
http://www.physicsforums.com/showthread.php?t=77835 It is a simple question but I am confused, if the slit or the slits are vertical the direction of the pattern is horizontal or vertical? Vertical: | | | | | | | | | | Or horizontal like in this video: http://www.youtube.com/watch?v=tu57B1v0SzI | | || | | | | | At the left is the two slits and at the right the pattern, the first one in the same direction of the slits vertical and the second one horizontal (It should go inside the screen) but It is hard to draw Which one is it? |
| Feb27-12, 12:34 PM | #2 |
Mentor
| Feb27-12, 01:55 PM | #3 |
Well expressed jtbell so is that what it happens or should it be rotated 90 degrees like: The bright and dark bands are each oriented horizontally, perpendicular to the slit(s), but they are spread out in a vertical pattern parallel to the slit(s)? |
| Mar4-12, 04:17 PM | #4 |
please can someone answer my question?
| Mar4-12, 04:22 PM | #5 |
Mentor
(not the single-photon-at-a-time version, but rather shining a laser beam through slits.) |
| Mar4-12, 05:42 PM | #6 |
Thank you jtbell
| New Reply |
| Tags |
| slit experiment |
Similar discussions for: slit pattern, vertical or horizontal?
| Double Slit Interference Pattern | Introductory Physics Homework | 1 | ||
| 2-Slit Intensity Pattern | Advanced Physics Homework | 1 | ||
| Absorbing Material Over a Slit in Deriving Double Slit Fraunhofer Interfernce Pattern | Advanced Physics Homework | 1 | ||
| Intensity of Double Slit Pattern | Introductory Physics Homework | 1 | ||
| Two slit interference pattern | Introductory Physics Homework | 1 | ||
