| New Reply |
pH of HCl solution as a function of volume. |
Share Thread | Thread Tools |
| Feb27-12, 11:44 PM | #1 |
You have a 1L of a 2M HCl solution. Assume that the HCl completely ionizes. a) Calculate the pH of the solution right now. b) You now add V litres of water to the solution. Find the pH of the new dilute solution in terms of V. 2. Relevant equations pH = -log[H] 3. The attempt at a solution a) pH = -log(2) which is interestingly a negative number so I hope this is correct. b) I'm not sure how you would do this part. Do we just find the new concentration in terms of V and then find the negative log of that? Don't we have to consider the autoionization of water? Thanks! BiP |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb28-12, 02:19 AM | #2 |
Admin
Yes, negative pH is possible.
Check the link I posted in your other thread for the way pH should be calculated. And read about dilution calculation. |
| New Reply |
| Thread Tools | |
Similar Threads for: pH of HCl solution as a function of volume.
| Calculate the volume of each reagent required to prepare 25.0 mL of each solution | Biology, Chemistry & Other Homework | 2 | ||
| Volume bounded by four surfaces. Need the solution as a guide. | Calculus & Beyond Homework | 1 | ||
| Increasing the volume of solution lowers experimental error? | Biology, Chemistry & Other Homework | 3 | ||
| Solution manual for Courant Volume I | Science Textbook Discussion | 3 | ||
| Determintion of the volume strength of the solution of hydrogen peroxide provided.... | Biology, Chemistry & Other Homework | 5 | ||
