New Reply
Thermodynamics - Calculate the initial temperature of the iron.
Share Thread Thread Tools
Feb28-12, 11:11 AM   #1
A 100g of hot iron rivets is heated to some temperature and then quickly transferred to 120g of water at 40°C in a copper calorimeter of mass 50g and specific heat capacity of 400J/(kg.°C).It is found that the final temperature of the mixture is 100°C and the water has lost20% of its mass to steam. If the iron has a heat capacity of 460 J/(kg.°C), calculate the initial temperature of the iron. (The latent heat of vapour is 2.26 m/kg)
2. Relevant equations
E= M x C x ∆T and E = M x L Are these the equations I am supposed to use?
3. The attempt at a solution
I don’t want an answer to this. There is lot of data in this question which is confusing me. Can anyone please break the question down for me into simpler form? Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Feb28-12, 11:32 AM   #2
Recognitions:
Homework Helper Homework Help
Heat lost by iron = heat gained by warming the water + heat used to make steam
Feb28-12, 12:12 PM   #3
Quote by Delphi51 View Post
Thank you Delphi51. :) I really appreciate your help. In the question they have given mass and heat capacity of copper calorimeter. I don't know what I need that information for and what I am supposed to work out first. Confused.com
I really want to work thisout myself but I am not gettin anywhere with this.
Feb28-12, 12:39 PM   #4
Recognitions:
I missed that! Good catch.
Heat lost by iron = heat gained by water + heat gained by calorimeter + heat used to make steam
Feb28-12, 02:51 PM   #5
Thank you so much. I know how to work it out now. This is going to be the last question (hopefully)
In the question it says iron quickly tranferred to water at 40°C in a calorimeter of mass 50g....
I will be using E=MxCxΔT for heat gained by water and calorimeter and add them together. Do I use that 40°C in this equation for both of them?
Like 120x4.2x(100-40) for water and 50x400x(100-40) for the container?
Feb28-12, 08:38 PM   #6
Recognitions:
Yes, the 100-40 looks good for both. 4.2 for the heat capacity does not look right. I seem to remember 4200. Better check it.
New Reply
Thread Tools
Similar Threads for: Thermodynamics - Calculate the initial temperature of the iron.
Thread Forum Replies
Thermodynamics - Calculate the temperature of helium if it's internal energy is 2x Introductory Physics Homework 2
how to calculate the density of an iron nucleus Advanced Physics Homework 2
calculate the gram of iron Biology, Chemistry & Other Homework 2
Calculate the resistance of iron if... Introductory Physics Homework 1
Temperature of Iron. Brain Teasers 16
