How much suction required to lift?
  • Context: Undergrad
  • Thread starter Thread starter Lisa Helme
    Lift Suction
The discussion focuses on the suction required to lift objects of varying weights and volumes, particularly in the context of dislodging objects from the throat during choking incidents. It highlights that suction acts unilaterally, which can exacerbate choking by collapsing the throat rather than effectively lifting the object. The analogy of using a drinking straw illustrates how rigidity affects suction efficiency, emphasizing the importance of maintaining structural integrity in suction devices.
  • Understanding of suction mechanics
  • Knowledge of fluid dynamics
  • Familiarity with choking hazards and first aid techniques
  • Experience with rigid versus flexible materials in suction applications
  • Research the physics of suction and pressure differentials
  • Explore first aid techniques for choking, including the Heimlich maneuver
  • Study the design principles of suction devices and their material properties
  • Investigate the effects of viscosity on suction efficiency in various fluids
Medical professionals, emergency responders, engineers designing suction devices, and anyone involved in safety training related to choking hazards.
Lisa Helme
Hi - am looking for some data points on how much suction is required to lift an object at different weights and volumes.
Especially interested in any data relative to displacing an object caught in the throat if you are choking.
Appreciate any help!
Well the problem with suction in this sense is that it acts in all directions unilaterally. i.e.
rather than pull an object out, it will have more of a tendency to collapse the throat, making the problem worse.
If you use a drinking straw to drink a milkshake, you're OK as long as the shake isn't too thick, and the straw is rigid. But if you flatten the straw, decreasing its rigidity, it will simply collapse every time you suck on it.
  • · Replies 30 ·
