| New Reply |
Poynting Vector - Finding stored energy per unit length of a solenoid |
Share Thread | Thread Tools |
| Feb28-12, 12:22 PM | #1 |
long solenoid of n turns per unit length is wound upon a cylindrical core of radius a and relative permeability. The current I through the solenoid is increasing with time t at a constant rate. Obtain expression for the rate of increase of stored energy per unit length in the core of the solenoid (a) from the inductance per unit length of the solenoid, and dI=dt. (b) from the energy associated with the fields internal to the solenoid core. (c) by integration of the Poynting vector over an appropriate surface. 2. Relevant equations None are given but I believe this is what should be considered: -∂/∂t ∫[ εE2/2 + B2/2μ ] dv = ∫ Jf dot E dv + ∫ E cross H da Ampere's Law E cross H = S 3. The attempt at a solution Using Ampere's Law: B=μnI L = flux/I L = μn2lA Where l is some length and A is a surface Part A) ∅ = L dI/dt ∅ = μn2lA dI/dt U = Q∅/2 U/dt = μn2lA (dI/dt) (Q/dt) (1/2) U/dt = μn2lA (dI/dt) I (1/2) This just does not seem right to me?? Part B) U = ∫B2/2μ dv U = ∫(μnI)2/2μ dv U = μn2lAI (1/2) U/dt = μn2lA (dI/dt) I (1/2) Part C) U = ∫ S dv where S = E cross H, assuming ∫ Jf dot E dv = 0 This is where I am confused. Is there an electric field in the solenoid? If so then did I not do the other parts correctly? What am I missing here... |
| Mar3-12, 02:57 AM | #2 |
Not that complicated. Given inductance L, what is the formula for stored energy?
Then, calculate L per unit length. |
| New Reply |
| Thread Tools | |
Similar Threads for: Poynting Vector - Finding stored energy per unit length of a solenoid
| electrical energy stored in solenoid | Classical Physics | 3 | ||
| Energy stored and # turns in an MRI machine (solenoid) | Introductory Physics Homework | 6 | ||
| Energy Stored in Magnetic Field of Solenoid | Introductory Physics Homework | 2 | ||
| Finding and using the Poynting vector | Introductory Physics Homework | 0 | ||
| Relating time averaged energy density to the Poynting vector per unit solid angle | Advanced Physics Homework | 3 | ||
