New Reply
Capacitors - Conservation of Charge vs Conservation of Energy
Share Thread Thread Tools
Feb28-12, 04:15 PM   #1
I am a TA for a physics teacher. I wrote a problem that the students did in the lab quiz. The students tried to use conservation of energy instead of conservation of charge, which I used. Both methods seem sound to me, but they produce different answers. I need help figuring out which method is correct, and why the other one is incorrect.
S2 is now opened after C1 has been fully charged and S1 is then closed. What is the final voltage?
2. Relevant equations
[itex]C = \frac{Q}{V}[/itex]
[itex]U = \frac{1}{2} C V^{2}[/itex]
3. The attempt at a solution
[itex]V_{0} = \text{initial voltage} = 3V[/itex]
[itex]C_{0} = \text{initial capacitance} = C_{1} = 470 \mu F[/itex]
[itex]Q_{0} = \text{initial charge}[/itex]
[itex]Q_{1} = \text{final charge on } C_{1}[/itex]
[itex]Q_{2} = \text{final charge on } C_{2}[/itex]
[itex]V^{'} = \text{final voltage}[/itex]
Conservation of Charge:
[itex]Q_{0} = C_{0} V_{0}[/itex]
[itex]Q_{1} = C_{1} V^{'}[/itex]
[itex]Q_{2} = C_{2} V^{'}[/itex]
[itex]Q_{0} = Q_{1} + Q_{2} = C_{1} V^{'} + C_{2} V^{'} = (C_{1} + C_{2}) V^{'}[/itex]
[itex]V^{'} = \frac{Q_{0}}{C_{1} + C_{2}} = \frac{C_{0} V_{0}}{C_{1} + C_{2}} = \frac{(470 \times 10^{-6} F) (3V)}{470 \times 10^{-6} F + 100 \times 10^{-6} F} \approx \textbf{2.474 V}[/itex]
Conservation of Energy:
[itex]U_{1} = \frac{1}{2} C_{1} (V^{'})^2[/itex]
[itex]U_{2} = \frac{1}{2} C_{2} (V^{'})^2[/itex]
[itex]U_{0} = U_{1} + U_{2} = \frac{1}{2} C_{1} (V^{'})^2 + \frac{1}{2} C_{2} (V^{'})^2 = \frac{1}{2}(V^{'})^{2}(C_{1} + C_{2})[/itex]
[itex]\frac{1}{2} C_{1} V_{0}^{2} = \frac{1}{2}(V^{'})^{2}(C_{1} + C_{2})[/itex]
[itex]C_{1} V_{0}^{2} = (V^{'})^{2}(C_{1} + C_{2})[/itex]
[itex]V^{'} = V_{0} \sqrt{\frac{C_{1}}{C_{1} + C_{2}}} = (3V) \sqrt{\frac{470 \times 10^{-6} F}{470 \times 10^{-6} F + 100 \times 10^{-6} F}} \approx \textbf{2.724 V}[/itex]
The answers are inconsistent. Which one (if at all) is correct?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb28-12, 04:31 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by vineel View Post
What are your own thoughts on the matter?
Feb28-12, 04:55 PM   #3
gneill,
I personally feel that my method (conservation of charge) is the correct one. I feel as if conservation of energy does not apply for some reason.
I am not sure at all, so I am posting this question.
Feb28-12, 05:46 PM   #4
Recognitions:
gneill,
We can't just give you an answer here (Forum rules), but we can help to a solution...
I suggest that you try a thought experiment. Suppose your circuit was the same as before but includes a resistance R between the two capacitors. Clearly some energy will be lost as heat in the resistor when S1 is closed and the current flows.
Write the equation for the current I(t) in the circuit and then find the energy lost by integrating I2R from time 0 to infinity. What's the resulting expression? What does it depend upon?
New Reply
Thread Tools
Similar Threads for: Capacitors - Conservation of Charge vs Conservation of Energy
Thread Forum Replies
Charge conservation in capacitors Electrical Engineering 22
linear momentum conservation vs mecanical energy conservation General Physics 1
Electrostatic charge and law of conservation of energy Classical Physics 32
Conservation of charge, but not conservation of energy Engineering, Comp Sci, & Technology Homework 0
Kirchhoff's First Rule - Electrical Charge / Energy Conservation Classical Physics 2
