Register to reply
Length of triangle
by bobsmith76
Tags: length, triangle
Share this thread:
bobsmith76
#1
Feb29-12, 10:16 PM
P: 339
3. The attempt at a solution
I can't figure out how thales found the measurement of the length of this triangle without trigonometry since the sine and cosine ratios were not worked out until the 14th century I think. In any case, they certainly weren't known in thales' time. using trig the answer is rather straightforward, but without trig the only method i can think of for obtaining the length of the bottom line of a right triangle is rather crude. what thales could do is redraw the triangle on the beach since if he knew the AB length and the DAC angle he could physically draw the BAP triangle on the beach, although it would be a rather large and crude replica of the real triangle, but that's the only method i can think of.
any help would be greatly appreciated.
Phys.Org News Partner Science news on Phys.org
Security CTO to detail Android Fake ID flaw at Black Hat
Huge waves measured for first time in Arctic Ocean
Mysterious molecules in space
tiny-tim
#2
Mar1-12, 06:38 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,157
hi bobsmith76!
Quote Quote by bobsmith76 View Post
maybe they weren't published in tables until then,
but the ancient greeks certainly knew all about similar triangles
see eg Heath's Euclid's Elements, free online at http://books.google.co.uk/books?id=h...elements&hl=en
bobsmith76
#3
Mar1-12, 11:47 PM
P: 339
I was reading about how Eratosthenes measured the Earth and I saw the word proportionate triangles. so that's probably what he did, he reduced the height of the new triangle by 1/10th or whatever and using the pythagorean theorem he could figure out by how much he should reduce the other triangle. maybe that's what you meant by similar triangles.
tiny-tim
#4
Mar2-12, 06:12 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,157
Length of triangle
according to wikipedia, he actually measured the angle itself (presumably using some sort of enormous protractor )
He also knew, from measurement, that in his hometown of Alexandria, the angle of elevation of the sun was 1/50th of a circle (712') south of the zenith on the solstice noon.
did you look at Euclid ?
Register to reply
Related Discussions
Finding the minimum length of a median in a triangle Calculus & Beyond Homework 31
Rest Length, Coordinate Length, and an argument for True Length Special & General Relativity 242
Applied Trigonometry, Deduce Length of Segment in new triangle. Precalculus Mathematics Homework 5
104.5 degree triangle w/ 2 equal legs, need the 3rd leg's length Introductory Physics Homework 5
NEED HELP Finding the length of an angle on a right triangle Introductory Physics Homework 8
